Old 11-12-2002, 04:38 AM
Veetec's Avatar
Veetec Veetec is offline
Send a message via ICQ to Veetec Send a message via AIM to Veetec
Pedals for heel-toe downshifting?
What are good pedals for hell-toe downshifting?? And how can I modify them so that the brake and gas pedal are on the same height on a 5th gen Prelude?
Thanx in advance!
Old 11-12-2002, 05:01 AM
hybridsol's Avatar
hybridsol hybridsol is offline
Send a message via AIM to hybridsol
Re: Pedals for heel-toe downshifting?
Thanx in advance!
seriously man I woulden't try to make a front wheel drive into a drifting car, make it drag worthy just an opinion. Ok is the car an automatic? or manual?
Old 11-12-2002, 07:51 AM
higgimonster's Avatar
higgimonster higgimonster is offline
assuming you find pedals to do this with you are going to want to stiffen up you brake pedal so that you squeeze it instead of moving it to slow down. It is a much harder feel but makes heel-toe shifting a lot easier.
Promoter of the one line signature.
Old 11-12-2002, 09:40 AM
Veetec's Avatar
Re: Re: Pedals for heel-toe downshifting?
What do you mean with drag worthy? (Sorry, Iīm german...) Itīs a manual of course. (Germans donīt like to drive automatic!! )
Old 11-12-2002, 01:28 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
drag car, ahh straight line racing. 1/4 mile. 400m. drag racing. 1320. 2 cars line up and go down a straight road as fast as they can and the first one to cross the finish line wins, usually a 1/4 mile
Old 11-12-2002, 08:22 PM
some people even live there life a 1/4 mile at a time.
And I am glad to hear germans don't like autos. There are way too many over here in the states. Who buys a corvette with an auto? seriously?!? many americans do. and they drive them at 55mph on the highway
Old 11-12-2002, 10:54 PM
hybridsol's Avatar
Re: Re: Re: Pedals for heel-toe downshifting?
who does? ok the pedals must also be properly spaced. In my buddies car it required adjusting and bending the gas pedal until I got the match I needed. In many cars, the pedals have some range of adjustment, making the process easier. One thing to remember, as you adjust the gas pedal, make sure that there is a mechanical stop for the pedal. If you rely on the stops in the injection system to stop the motion, you will probably bend or break something as you try to squeeze a couple more horsepower out of the pedal. Also, make sure the linkage is fully open when the pedal hits your mechanical stop.
Old 11-13-2002, 04:23 AM
Veetec's Avatar
Okay, I see! I know what drag racing is but I thought he was talking about something special...
Thanx anyways....
Old 11-13-2002, 04:30 AM
Veetec's Avatar
Re: Re: Re: Re: Pedals for heel-toe downshifting?
Do I have to adjust the gas pedal?? I wanted to use some kind of chims (what material?) to raise the gas pedal like described here: http://www.turnfast.com/tech_driving...g_pedals.lasso
Old 11-13-2002, 12:20 PM
hybridsol's Avatar
Re: Re: Re: Re: Re: Pedals for heel-toe downshifting?
I know razo makes pedals - http://68.36.226.92/porschepage/exot...hmt/mymr2b.htm
in this link do you see the distance between the pedal's that is what i'm reffering to. height is a little rasied to the break but I believe the gas pedal must only be angeled.
Old 11-14-2002, 12:47 AM
Frostbyte Frostbyte is offline
Send a message via ICQ to Frostbyte
I thought the advantage of heel toe was to keep your turbo spooled around corners huh learn something new everyday
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
JIC Magic Front and Rear Strut Bars
Slotted and Cross-drilled Rotors
S/S Brake Lines
Pivot Lazy eye controller
Blitz LM Intake
Blitz D1 Spec Turbo Timer
Soon to come:
Sard 550cc Injectors
Blitz Nur Spec Exhaust
Blitz Down pipe
HKS FMIC
http://www.driftmonkey.com (Part Owner)
Old 11-14-2002, 01:28 AM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
That is true I think, but in an N/A car, I believe that technique is used to keep the engine at constant revs around curves while shifting 9manual tranny of course). It's so that you don't loose any umpf in your powerband while shifting and accelerating, keeps the ride smooth as well.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 11-15-2002, 06:20 AM
Veetec's Avatar
Thanx a lot for your help! I think Iīll get some OMP pedals because they seem to be quality stuff, they are not too expensive and I can get them easily compared to Razo, Mugen, etc. here in germany.
Old 11-15-2002, 06:54 AM
hybridsol's Avatar
goodluck man, let me know how everything turns out.
Old 11-26-2002, 10:51 AM
eklipz eklipz is offline
Thats the gayest saying ever.
http://mindsys.serveftp.org
