| F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
91 camaro big problem
91 camaro v6 3.1 t tops rs
im having problems keeping it running it will run perfect for about 15 min then die out not starting for several days then out of the blue it will run perfect again for another 15 min i have changed the computer,distributer,fuel pump,fuel filter ,ignition coil , fuel pressure regulater,iam getting fuel allthe way up and i am getting spark this is driving me can any one help
Re: 91 camaro big problem
Might check the EGR valve.H
Have you checked the trouble codes? |
When it won't start, exactly what happens? Is it popping? Or just flatline while turning over? Pull a few plugs and sniff. Flooded? Spark check. What about gettin gas into the cylinder manually to see if it fires?
![]() '67 Camaro 350 - driver, '83 Z28 305 (off the ECM), and T5 '91 RS 305 T5, 2000 C5 2000 Trans Am I don't drive the Fords |
