Old 08-04-2007, 10:00 AM
hot3000's Avatar
hot3000 hot3000 is offline
Electrical Issues
So i've been havin some electrical problems, i think. first off my radio... pretty often lately it seems my front speakers cut out and i thought it was the speakers themselves, but i checked them and they are fine but every once in awhile its like all the bass out of all the speakers go out and the rear speakers are running on just treble and gets really quiet. idk its kind of hard to explain. at first i thought maybe it was my amp but the amp is unplugged and did it even when it was plugged in so it rules that out. now im thinking maybe its the head unit??
secondly, over the past couple of weeks my stock alarm system will just cut on and off randomly. it did it twice within 5 mins yesterday. if i leave my doors unlocked it doesnt do it. but if the doors are locked, whether security is engaged or not, it goes on and off intermittently. sometimes it stops by itself, sometimes it doesnt stop until i go out and put my key in the door and unlock it. also, the only way i can get my security system to engage is if i have the passenger door open when i lock my doors. every once in awhile it will do it without the passenger door open first.
thirdly, my headlights. at night, when my lights are on and i cut my car off,take the key out of the ignition and open my door, the headlights are supposed to cut off. well lately, it doesnt do it. and the lights will stay on. the interior lights only come on sometimes when the doors are open, sometimes they dont.
soooo, the other stuff i can deal with but this alarm stuff is really starting to piss me off.
any help or ideas would be much appreciated
Old 08-04-2007, 01:43 PM
new2mitsu new2mitsu is offline
Re: Electrical Issues
I'd just unhook the alarm, i think the factory alarm is junk anywho. As for the interior lights, im sure its a bad connection to the switches in the doors, on mine the drivers side wont turn the lights on, but the oassenger side will, and if i sit there and fiddle around with it, it'll start to work, i need to re wire it, im just lazy. The headlight thing is kinda a mystery. do you have stock speakers and head unit, or aftermarket?
Old 08-04-2007, 01:59 PM
hot3000's Avatar
its all stock. and though some people may just use the easy route and unhook the alarm, i could have easily thought of that myself. i want it fixed not put off.
Old 08-06-2007, 10:08 AM
hot3000's Avatar
this sucks, i hate leaving my car unlocked. but it seems the only way to keep my alarm from going off
Old 08-06-2007, 11:52 AM
well, in that case, this could be a good oppurtunity to upgrade to a better alarm? on the speakers, does it seem like the balance and the fade are constantly changing?
Old 08-06-2007, 12:29 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
for the alarm, that just sucks. when alarms act up, you're always SOL. there have been soo many problems with the stock alarm, that its probably worth getting an aftermarket one. i would try to disable it for the meantime so you can lock your car without the possibility of it randomly going off. that, or simply disconnect the siren.
for the speakers, do you have the stock stereo? stock speakers?
as for the headlights staying on after door is open, troubleshoot the ETACS (electronic timing and control system). your dome light comes on, so it working partially. maybe a relay in the system is sticking that would otherwise turn the headlights off. really not sure.
hopefully Stealthee will respond.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 08-06-2007, 01:36 PM
hot3000's Avatar
again, yes its all stock. Though the balance doesnt really change much more the fade i suppose. guess ill just not worry about the alarm since i wanted to get remote start and alarm anyways. i guess i was just hoping it would be a quick fix until i actually shell out about 200 bucks to do what i want. oh well
btw where is the ETACS located? vector can u check it in two weeks?
Old 08-06-2007, 02:04 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
LMAO.
For the headlights the door switch is actually a "double switch" I have had instances where the dome light came on when the door was opened but the headlights stayed on. I just reached down and wiggled the switch and voila, headlights go off. The door switch gets dirty and needs the contacts cleaned sometimes. That could be a reaon why the alrm wants to go off.
Old 08-06-2007, 02:55 PM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
if the driver door is locked and closed while the passenger door is still open...then your alarm is gonna tweak out and start going off by itself, you may leave and a half hour later you alarm will be going off
make sure the passenger door is closed first, then lock your door and close it, and you shouldnt have the problem anymore
Old 08-06-2007, 07:57 PM
hot3000's Avatar
i never said the driver door was locked and closed first, both doors are open and unlocked then i lock them and shut the doors.
Old 08-07-2007, 01:49 AM
youngvr4's Avatar
STREET RACING GURU
so every time you lock the doors and close them, the passenger door is closed first or never opened at all?
Old 08-07-2007, 04:55 AM
youngvr4's Avatar
STREET RACING GURU
reason i'm saying that is because my car does the same thing
but i figured out it only does that when i locked the doors and shut my door before the passenger door was closed
the alarm then starts tweaking out
Old 08-07-2007, 06:11 AM
Stealthee's Avatar
If thats the case with yours young you need to clean the contacts on your passenger side door switch.
Old 08-07-2007, 08:31 AM
hot3000's Avatar
the passenger door is closed first.
Old 08-09-2007, 01:20 PM
Dave57's Avatar
Dave57 Dave57 is offline
Sounds like a bad hu, Bend the hood switch up on the alarm. get a new door switch for $7
'95 RT/TT Firestorm Red one of 61 MSRP $37,448.72 Digital Climate Control Conversion, DR-500 turbos, RPS, ARC-2,
03 Mitsu Infinity VRX System, Diamond D971 Components, JL e6450, JL W3.
