Old 08-04-2007, 07:30 AM
intel_guy intel_guy is offline
Best brake fluid
I'm going to be installing my new Russell SS brake hoses this weekend and am wondering if there is a strong preference of one brake fluid over another. The rest of the system is stock. Is a DOT4 better than DOT3 or for our application is it just a waste of $$$? I was looking at Motul DOT4 racing fluid.
Old 08-04-2007, 07:51 AM
taillight taillight is offline
Re: Best brake fluid
DOT 3 and make sure it is a new can not something that was open.
Old 08-05-2007, 03:23 AM
Excellent advice since a few weeks back I found that WalMart had opened/used gallons of Rotella Synthetic 5W40 Oil on their shelves. I'm actually not going to do it myself after all. There's way too much rust on the lines. I'm going to get the hard lines replaced as well.
Old 08-05-2007, 09:02 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
You did not say what year.
Most master cylinders or filler caps have the brake fluid specs on them and owners manual also.
If over 3 years or 50k on the bake fluid i would recommend a brake fluid flush for the system.
Bake fluid draws moisture which rust and cause containment of inside parts.
But some systems require a scan tool to do a total bleed operation.
MT
Old 08-05-2007, 07:41 PM
Sonny01's Avatar
Sonny01 Sonny01 is offline
I tried to put new Russell SS brake hoses on my 2000 1500 LS ext cab and the fittings didn't fit.
I use Super Blue Racing Fluid and you can really tell when you have all of the old stuff out of the lines because the fluid is blue....the next time use Dot4 and you can see the color change back and know all of the old fluid has been flushed.
Old 08-06-2007, 06:57 AM
It's a 99 4.8 w/150k. I topped off the reservoir with Valvoline Syn Power DOT3/DOT4 fluid. It wasn't empty, but it was below the min mark. When the repair is done I'll get them to drain flush and fill the system even though it was done last year (6k miles ago). Good idea about the off-color fluid. I guess when you flush it again you'll have to use a different fluid (unless they make red/clear)
Old 08-07-2007, 11:09 AM
stick64's Avatar
stick64 stick64 is offline
What would be the proper method of getting rid of the old fluid from your system on a 99 Silverado and 2000 S-10 Blazer ?
thanx
Old 08-07-2007, 10:28 PM
Sonny01's Avatar
That's right...I used the Super Blue because it's as good as the regular fluid and blue and next time I'll switch back for the color change.
