| Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here. |
85 mustang question. . .
I own a 1985 ford mustang and i was feeling the need to add some power to it, But i dont really know where to start. The problem is that it is a 1985 lx confertable which it nice as far as driving goes, but stock it has very little power for a 302. The car has a 2 bbl throttle body "cfi" and single exaust, and everything else factory. From what i can tell i need more air and fuel. my computer system seems to be a little greedy with the fuel but i dont know how to get it to change without replacing with a carb, and even then i dont know what size carb would be good. . Where would you guys start out?
Re: 85 mustang question. . .
I don't know crap about those set ups, sorry. I do know a lot of guys dump those set-ups and just go carb.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper. |
well it sounds more like i need to go with the carb then.. Has any one have an idea on how large i can go without it being too big, or weather or not i should consider some long tube headers and dual exaust first?
Go 600, that will give you room to grow, heck that is even overkill for even a modded 302.
You could either get the EFI system from an '86-93 5.0 HO or go with a carburetor. Don't go any larger than 600cfm. A Weiand Stealth dual plane intake manifold would be a good upgrade. You will need a low pressure(~3-5psi) fuel pump with the carb. I'll take the CFI injectors off your hands if you get rid of them.....
Ditch the single exhaust no matter what. You can get '86-95 stock tubular headers fairly cheap. Above all, set some goals for what you want. From there we can make more specific recommendations.
1968 Mustang notchback Roller 302, Edelbrocks, Hookers, side-exits, RRs, Crane 2031, Duraspark, forged slugs, X-Celerator, 650DP, Fidanza FW, RAM clutch, Toploader, Comp Plus, McLeod bell, 15x7s, 1 1/8 swaybar. 1972 Ford Pinto SVO 2.3 turbo, MegaSquirt, T5, 8", etc. '95 Honda XR600-10.5:1, 628cc, ported head, & more. |
That raises another question, can you pass emmisions without an egr unit, because 99% of the carb manifolds i can find dont have it? or on a carb set up does it fit between the carb and the manifold, because my current one is on the manifold.
In the begining, My first, and probably cheapest HP came thru headers, then carburation mods. I had big valves, and a cam to match; The cam, valves and headwork came later, and at a much higher price tag. For your situation, I would suggest a 650 - 750 CFM 4 bbl w/ vacuum secondaries, long tube headers, free flowing dual exhausts, and a cold air intake. If possible, try to mechanically advance (IE: physically move the distributer) your initial timing about 8* AHEAD of stock for more power and mileage. Good Luck!!
Stale Trooper '05 CVPI (My '99 got wiped out with 238,513 miles on the clock, stupid woman driver) It's White, with a black grille, a spotlight, and the butt is black. Need a picture? Thought not
