Go Back   Automotive Forums Car Chat > Chevrolet > Chevrolet Classics
Old 08-03-2007, 04:46 PM
streetrcr4 streetrcr4 is offline
350 turbo trans
I have a 350 turbo in a 66 nova that is making a howling sound, similar to a rear end. Does anybody have any ideas what would cause that?
Old 08-04-2007, 07:58 PM
Blue Bowtie's Avatar
Registered Offender
Re: 350 turbo trans
Howling in any particular range/gear? That's not really uncommon in 1st at higher RPM.
Old 08-04-2007, 08:30 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: 350 turbo trans
My $.02 would be torque converter, or front pump. There may be some cavitation, which could indicate a restricted filter.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 08-09-2007, 04:24 PM
Re: 350 turbo trans
Does it in all forward gears. I'm not sure that it is the trans for sure, but I took the rear end apart and didn't see anything wrong there.
Old 08-09-2007, 04:27 PM
Re: 350 turbo trans
I just rebuilt the trans over the past weekend and it is still making the exact same noise. I'm wondering if it could possibly be the pinion bearing? that is the only thing that I didn't look at while I had the rear end apart.
Old 08-09-2007, 07:37 PM
silicon212's Avatar
Confoundingly Lucid
Re: 350 turbo trans
Did you put a new torque converter in it? No? Shame on you. That's the cause of the noise.
Old 08-12-2007, 02:38 PM
Re: 350 turbo trans
It's not the torque converter, had it gone thru..
Old 08-12-2007, 02:50 PM
silicon212's Avatar
Confoundingly Lucid
Re: 350 turbo trans
How was it 'gone through'? It's hard to check one of these without cutting it apart. You can check stator operation, but wear won't always show up on some pressure test or whatever.
With many years of TH350 experience, I can tell you the cause of a 'whine' on one of these transmissions is almost always front pump or TC related. With the ridiculous low cost of TH350 replacement torque converters, it's a false economy to 'save money' and not replace it during a rebuild. As MT-2500 so eloquently puts it, you can get bit in the butt once, or you can get bit in the butt many times - the latter is what happens when you don't replace a torque converter during install.
Old 08-16-2007, 03:50 PM
Re: 350 turbo trans
Well, I did have it cut open, cleaned and checked. I also put a new front pump in it when it was rebuilt. Anyway, turns out it is the pinion bearing, but thanks for the input.
