Go Back   Automotive Forums Car Chat > Nissan > Almera | Sunny | Pulsar | Bluebird | Tiida | Versa | NX | Avenir | Tino | Stanza
Old 08-03-2007, 12:20 PM
aeflower9 aeflower9 is offline
Exclamation 93 nx 2000
i just found a 93 nx 2000 with 171000 miles on it. car looks untouched and i was wanting to know how good are the engines and if it would blow what kind of engine could replace it.. thanks for your help
Old 08-04-2007, 11:22 AM
mmcleo11's Avatar
mmcleo11 mmcleo11 is offline
Re: 93 nx 2000
The NIssan SR20DE motor is near bullet proof if it is properly cared for. If it dies, it is easy enough to head over to the sr20forum.com website and find another SR20DE engine for it. However, you can also fit the turbo version called the SR20DET or there is a later model non turbo motor called the SR20VE. Both transplants are easily installed and can make the little NX a rocket
N14 Pulsar
VQ35 conversion with major N/A upgrades, 6 spd FWD manual HLSD
18" Rims, big brake kit, Coil overs and freshly painted
Smashed Black VY SS Ute
The workhorse...
Twin turbo 5.7L LS1
Boyd Coddington 19" Turbine Wheels
AP Racing 4 Piston Brakes
Tein Coil over Suspension
HKS EVC 6 Boost Controller
PLX Devices DM-200 OBDII
Custom Front Mount Intercooler
Old 08-04-2007, 06:00 PM
Re: 93 nx 2000
will any of the sr20de engines fit in the nx or just certain years. and what should i look for before i buy anything that goes bad that i should have checked out on the car. someone said something about the a arm or something thanks guys and about what should i pay for this car body looks real nice thanks
Old 08-08-2007, 08:23 AM
mmcleo11's Avatar
Re: 93 nx 2000
From 1991 to 1995 from any of the FWD(front wheel drive) SR20's
Check the engine mounts are not worn, the suspension is good and importantly, that the clutch is not making any noises.
N14 Pulsar
The workhorse...
Twin turbo 5.7L LS1
Old 08-09-2007, 10:35 PM
niceman niceman is offline
Re: 93 nx 2000
sr20de engines fit in the nx as well as the nissan 280zx radiator.
Old 08-12-2007, 09:07 AM
mmcleo11's Avatar
Re: 93 nx 2000
Bloody idiots. The 280ZX radiator does not fit the FWD NX engine bay at all. The tank outlet points are wrong and the mounting points are different... Sure looks like youknow your stuff
N14 Pulsar
The workhorse...
Twin turbo 5.7L LS1
