Go Back   Automotive Forums Car Chat > Mercury > Villager
Old 08-03-2007, 10:03 AM
gibbydad gibbydad is offline
1995 Villager Won't Turn Over
Ihave a 1995 Villager that started having intermittent starting problems about a year ago. I have replaced the starter, a relay and most recently the transmission position sensor. Prior to replacing the position sensor you could rock the van while in park and then it would usually start. That is why I thought it was the position sensor. Now that I have replaced the sensor, it will not turn over at all. When I turn the ignition switch the fuel pump engages, the fan and radio turn on, etc. I am just not engaging the starter motor. I am really not sure what is going on at this point... Any help would be appreciated.runaround
Old 08-04-2007, 02:18 PM
steamplant steamplant is offline
Re: 1995 Villager Won't Turn Over
Try starting it in the neutral positon, it sounds like the tranny position switch needs ajustment.
Old 08-07-2007, 06:30 PM
Thank you for the response. In actuality, I found a broken wire leading from the transmission position sensor plug going to the starter. I fixed the wire and the car started right up.
