Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 08-03-2007, 09:27 AM
tim46804 tim46804 is offline
99 Ranger Tranny shifting hard
99 Ranger/ Automatic / 305 motor
As I begin to accelerate from 1st gear..prior to shifting to 2nd gear..the RPMs seem to run alittle higher then normal and when it shifts to 2nd it shifts a little hard. I can feel a little jerk when it shifts. No problems with the other gears only from 1st to 2nd.
Old 08-03-2007, 11:04 PM
toddler62 toddler62 is offline
Re: 99 Ranger Tranny shifting hard
Sounds like your clutch might be worn out. how many miles on this clutch?
Old 08-03-2007, 11:43 PM
DonSor DonSor is offline
I thought I read 99 Ranger/Automatic/305.
Sounds like you have a delay between first and second. You may have to see an auto tranny mechanic to do pressure point test. I find auto trannies to be a wee bit complex of an equipment.
Old 08-04-2007, 08:57 PM
viper753 viper753 is offline
If it is just doing it from 1st to second, it might possibly be the VSS in the rear axle. I had the same problem with mine and my Ford Mech friend had me change that.
If that doesnt fix it, and there is a small possibility that it wont, then your tranny needs replacing.....did that also....
The VSS is very inexpensive to change out so I would try that first.
Does the tranny have problems when you are at speed and hit the gas?
Old 08-08-2007, 12:23 PM
Its an Automatic Trans.
Old 08-08-2007, 09:39 PM
I caught that after I posted. Just ignore what I wrote
Old 08-22-2007, 02:58 PM
goldberg_52403 goldberg_52403 is offline
Just an idea, but since it is a few years old, maybe a dirty transmission filter could be the problem?
Might not be a bad idea to get the filter changed and the fluid flushed.
