Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 08-03-2007, 07:50 AM
Denbis Denbis is offline
2000 Sunfire GT - Stiff Gear Shift
Hi folks. 2000 Sunfire GT; 2.4L; 190,000km; Automatic Transmission
Fairly simple to explain (I think).... When moving the stick/gear shift from Park to Drive, 3, 2, 1, it is stiff and gets progressively worse to the point where I can't even get it into the 1st gear!
Before I take this puppy to the garage, I am seeking any input/insight on possible causes for this problem. Note: this is probably not a factor, however, the engine was replaced last October.
Thank you for you time and replies.
Old 08-04-2007, 08:15 PM
ChemMan ChemMan is offline
Re: 2000 Sunfire GT - Stiff Gear Shift
This is likely a cable that is in need of lubrication and probably a little bit rusty. You are probably going to need to pull up the center console to get to the shifter and cable and apply a little white grease. Check that the cable isn't twisted or something that would cause binding and you should be fine.
2010 Mazda CX-7 2.5L 12000 miles
2003 Chevy S10 Extreme 4.3L 57000 miles
1995 Buick Lesabre Custom 86000 miles RIP
2002 Pontiac Sunfire SE 130000 miles RIP
1997 Pontiac Bonneville SE 91106 miles Totaled by attempt to steal the car!!
R.I.P. 1978 Ford Fairmont 83000 miles
