Old 08-03-2007, 07:30 AM
98gpking 98gpking is offline
Send a message via MSN to 98gpking
A/C problem
well heres the scoop. to make it short and simple when i turn the A/C off theres a loud high pitched rattle coming from under the hood where all the pulleys are(front of engine) when the A/C ON the sound goes away. i dont know if its a bad pulley or a bad A/C unit.
it would seem to make more sense that when i turn the A/C on the sound would come not when i turn it off.
any ideas?
i can possibly get a video/sound clip if youd like
2000 grand prix GTP. CAI, 180 t-stat, u-bend and res delete, custom tuned PCM, shift kit
Old 08-03-2007, 09:55 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: A/C problem
Check the pulleys themselves particularly the belt tensioner. When the AC is on there is more tension on the belt. When you shut it off the tension is released and then you hear the noise.
Old 08-03-2007, 09:58 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: A/C problem
sounds like the compressor clutch bearing to me. It may need to be replaced. Some shops can do this without even evacuating the system.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 08-03-2007, 11:55 AM
Re: A/C problem
how do i go about checking the pulleys and tensioner
also how do i know if the clutch bearing is bad.
Old 08-03-2007, 11:43 PM
tblake's Avatar
In God We Trust
Re: A/C problem
you take the belt off and spin each pulley by hand, feeling for binding or roughness.
