Old 08-03-2007, 03:13 AM
pop826 pop826 is offline
1991 f150 timing
What To Disconect To Set Timing On 4.9 Motor
Old 08-21-2007, 10:44 PM
mightymouse466's Avatar
mightymouse466 mightymouse466 is offline
Re: 1991 f150 timing
You don't disconnect anything. Get yourself a timing light. Connect the power clips to your battery and the other clip over your #1 ignition wire. Check timing on harmonic balancer. If it need adjusted loosen the distributor hold down clamp and very slowly turn distributor one way or the other. Tighten clamp.
Old 08-22-2007, 07:57 AM
taillight taillight is offline
You need to set the computer into base timing. Pull the green plug near the distributor. Then set the timing at idle speed.
