Old 11-11-2002, 05:31 PM
sahrents sahrents is offline
2003 Silverado LT keyless entry programing.
I need to reprogram one of the fob's on a 2003 Silverado HD1500.
What is the process for reprograming the remotes since they are individually programed to each driver. The remote sets the seat, radio, mirrors, and temp settings as set by driver 1 or driver 2.
Old 01-03-2003, 07:52 AM
Shortbus Shortbus is offline
Blah blah blah
Send a message via AIM to Shortbus
I believe the transmitters will be labeled 1 and 2. This will denote driver one and driver two. Once you set your seat, radio, and mirrors the remote will automatically adjust that. I will include the program procedures for those to.
Transmitter Programming
Important
Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle.
There are 3 methods for programming transmitters which are listed below as method 1-3. Up to four transmitters may be programmed to the passenger door module (PDM). Each programmed transmitter is given a position of #1-#4 in the PDM memory.
Method 1 - No Tools Required, Program All Transmitters
Important
All transmitters which are to be recognized by the PDM must be programmed in a single programming sequence. When using this program method, all previously programmed transmitters will be erased upon the receipt of the programming signal from the first transmitter.
The order in which the transmitters are programmed will determine its numbering position within the PDM memory. The first transmitter programmed will be transmitter #1, and the second transmitter programmed will be transmitter #2. The number stamped on the transmitter case is for reference only: #2 can be programmed as #1, or vice versa. Additional unnumbered transmitters are also available.
Close all the vehicle doors.
Insert the ignition key into the ignition lock cylinder.
Press and hold the door unlock switch.
While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
Release the door unlock switch. The doors will lock and unlock to confirm the program mode.
Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of approximately 15 seconds, the doors will lock and unlock to confirm the programming of that transmitter.
Repeat the previous step to program up to four transmitters.
Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter programming mode.
Operate the transmitter functions in order to verify correct system operation.
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxx
Driver Personalization
Memory Seat Programming
Perform the following actions in order to program the memory seats for 2 separate drivers. Both outside mirrors and the radio station presets can also be programmed with the seat position:
Move the seat to the desired position. Include the recliner, lumbar, and side wing area seat position.
Press the correct memory seat button for the specific driver and hold for 3 seconds. After pressing the switch a double chime should be heard.
Repeat the steps for the second driver.
Easy Exit Seat Programming
Perform the following actions in order to program the memory seats for 2 separate drivers:
Press the correct memory seat button for the specific driver. The seat will move to the last stored memory position.
Move the seat to the desired exit/entry position.
Press the exit button and hold for 3 seconds. After pressing the switch a double chime should be heard.
Programming Features with the Driver Information Center
To enter programming with the DIC, perform the following actions:
Turn ON the ignition with the engine OFF.
Ensure that the vehicle is in PARK or that the park brake is applied.
Press the personalization button on the DIC to scroll through all of the personalization options.
Automatic Locking/Automatic Unlocking
Continue with the following steps in order to program the automatic door locks feature:
The DIC displays LOCK DOORS: OUT OF PARK, MANUALLY or WITH SPEED.
Press the select button in order to scroll through the above choices.
Press the personalization button in order to select the displayed choice and to advance to the next option.
The DIC displays UNLOCK: ALL IN PARK, ALL AT KEY OUT, DOORS MANUALLY or DRIVER IN PARK.
Press the personalization button in order to advance to the next option.
Remote Activation Verification
Continue with the following steps in order to program the remote activation verification feature:
The DIC displays REMOTE LOCK FEEDBACK: HORN, LAMPS, BOTH, or OFF.
The DIC displays REMOTE UNLOCK FEEDBACK: HORN, LAMPS, BOTH, or OFF.
Headlamp Delay
Continue with the following steps in order to program the headlamp delay feature:
The DIC displays HEADLAMP DELAY: OFF, 10 SEC, 20 SEC, 30 SEC, 60 SEC, 120 SEC, or 180 SEC.
Perimeter Lighting
Continue with the following steps in order to program the perimeter lighting feature:
The DIC displays PERIMETER LIGHTING: ON or OFF.
Seat Position Recall
Continue with the following steps in order to program the memory position recall feature:
The DIC displays SEAT POSITION RECALL: ON REMOTE, AT KEY IN, or OFF.
Easy Exit Seat
Continue with the following steps in order to program the exit position recall feature:
The DIC displays SEAT POSITION EXIT: ON or OFF.
Curb View Assist
Continue with the following steps in order to program the Mirror Reverse Tilt feature:
The DIC displays CURB VIEW: PASSENGER, DRIVER, BOTH, or OFF.
When the vehicle is shifted into REVERSE and the Mirror Reverse Tilt feature is activated, any adjustments made to the preset position now becomes the new set position stored, this feature can be customized for each driver.
Alarm Warning Type
Continue with the following steps in order to program the alarm warning feature:
The DIC displays ALARM WARNING: HORN, LAMPS, BOTH, or OFF.
Display Language
Continue with the following steps in order to program the language displayed:
The DIC displays DISPLAY LANGUAGE: ENGLISH, FRENCH, or SPANISH.
Display Units (ENG/MET)
Continue with the following steps in order to program the display units:
The DIC displays UNITS: ENGLISH or METRIC.
Exit Programming
The following actions end the programming session:
The ignition is turned OFF.
The programming timer of 15 seconds expires.
The personalization button is pressed until the DIC scrolls through all of the personalization options.
Additional Information
For more information on the personalization features, refer to one of the following description and operations:
Refer to Power Door Locks Description and Operation in Doors for more information about the automatic door locks feature.
Refer to Interior Lighting Systems Description and Operation in Lighting Systems for more information about the following features:
Headlamp delay
Perimeter lighting
Refer to Keyless Entry System Description and Operation in Keyless Entry for more information about the remote activation verification feature.
Refer to Memory Seats Description and Operation in Seats for more information about memory seats.
© Copyright General Motors Corporation. All Rights Reserved.
Old 07-26-2003, 08:00 AM
jstain jstain is offline
I have a 2003 Silverado, which is called a work truck,meaning it had virtualy no options. The keyless entry was not installed when it was manufactured. I found a set on Ebay, which supposedly will work.
I called the dealer to verify my part was correct, however they needed the VIN to check. Inasmuch as it didn't have it installed at the factory the dealer/GM database shows it's not installed, so they can't tell me if it will work.
UUUGGGHHH, any ideas?
recv'r P/N 15042969
Fobs P/N 15042967
Old 01-19-2004, 10:40 PM
betabob betabob is offline
Re: 2003 Silverado LT keyless entry programing.
[quote=John]I believe the transmitters will be labeled 1 and 2. This will denote driver one and driver two. Once you set your seat, radio, and mirrors the remote will automatically adjust that. I will include the program procedures for those to.
Important
*snip*
*snip*
Can you access the DIC without the Steering Wheel Controls? Is there a module that will submit the right commands through the ODBCII connector? And or can you just replace a non-buttoned wheel with a buttoned one?
Thanks!
Beta
