Old 08-03-2007, 01:35 AM
dannydanny dannydanny is offline
Escort Revving like mad when clutch is dipped
I have a 1998 Escort 1.8 Zetec. When I dip the clutch the revs go up like crazy, especially in 1st gear or when stood at lights.
Any ideas would be appreciated!
Old 08-03-2007, 01:48 AM
Re: Escort Revving like mad when clutch is dipped
Apparntly, the AIC valve is a likely candidate. Where abouts would I find this on the car to clean it?
Old 08-03-2007, 02:09 AM
mightymoose_22's Avatar
mightymoose_22 mightymoose_22 is offline
I would certainly suspect the IAC valve. I am not certain about the 98 model, but the IAC should be located where the large air intake hose connects to the intake manifold... usually about the size of a couple D cell batteries.
Old 08-11-2007, 05:17 PM
Can someone please show me where the thing is as I can't find it
Old 08-11-2007, 05:52 PM
Follow that large black tube toward the back side... look for the IAC which looks like this picture:
You will also be able to find it by following your throttle cable.
Old 08-11-2007, 05:58 PM
Hi
thanks for that, I have seen a pic of the aic before but there is nothing that seems to look like it.
Old 08-12-2007, 08:50 AM
12Ounce 12Ounce is offline
Follow the throttle cable to the throttle body ... now look on the opposite side (away from the cable hook-up) ... that's the throttle-position-sensor. Now go back a half-circle ... don't know which way, but probably away from the engine block ... you should find the IAC valve. May have a plastic cover. May not have a vacuum hook-up ... depends on application. Will have an electric connection.
