Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 08-03-2007, 12:05 AM
MrBrown's Avatar
MrBrown MrBrown is offline
getting ready to swap 700r4s
what would i need to change the 27 spline tranny to the 30 spline 700r4? My 84 caprice is starting to kill the 2-3 shift and the shifts can sometimes be eradic. super street fighter tranny, (Rated up to 600 Ft.-Lbs!,)is one click away from being ordered. also, does this seafoam stuff work? I have a bad lifter tick and it says on the bottle it removes lifter tick. Im pretty sure the cam lobe isn't worn because it will do it only very occasionally for a day or two but its not going away. any response is greatly appreciated. thank you.
Myself depicted in smilies.
Old 08-03-2007, 02:09 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: getting ready to swap 700r4s
Just get a transmission and torque converter from 1985 or newer for 30-spline. It's the input shaft.
All of them have the same tailshaft yoke size and spline count, which is interchangeable with the TH350 and older transmissions.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 08-09-2007, 12:35 AM
MrBrown's Avatar
so i can swap the trannies with no problem?
Old 08-09-2007, 01:35 AM
silicon212's Avatar
Confoundingly Lucid
As long as you use the proper torque converter, yes - no problem. A 27-spline converter will not physically fit a 30-spline input shaft, while the 30 TC will go over a 27-input, but you get no drive and a whole hell of a lot of noise, plus a damaged torque converter and input shaft.
Old 08-09-2007, 08:57 PM
MrBrown's Avatar
oohhh! ok i totally forgot the auto trans bolts to the flywheel instead of like a manual trans.
