My Camry has some turning signal problems. When I turn the signal either left or right it does not respond to flash when it is locked. I have to do it manually with my hand (up and down movement w/signal cylinder)
. I checked the bulbs which are fine and I replaced the fuse and flasher. I would really appreciate it if anyone could provide me with details. I have to go to a trip to New York with my family, so this is VERY necessary.Thanks! |
Re: 94 Camry Turn Signal/Flasher Problems
Could anyone help, please.
You're likely missing a ground or the turn sig switch is bad. Open your factory maintenance manual listed at the top of the forum for schematics and test procedures for your switch.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds. **Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual. 07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan |
If you can operate your turn signals manualy the problem is most likely in the switch itself.
It is possible to repair it. Disconnect your battery, remove the steering wheel and you will be able to get to the switch. If it cannot be fixed, junk yard is your best bet. I was able to buy a turn signal switch for my Isuzu for 16 dollars vs dealer's 162. Good luck, Sam
Thanks for the help! I'll try it today! Where do I find the manual on this page? I have my own manual, do you think it has that in mine?
Oh never mind I found it! Which topic do I select? The 1994 Camry Wiring Schematics ?
Good luck, Sam
Make Sure You Disconnect The Battery So You Don't Blow The Airbags.
