Old 08-02-2007, 03:51 PM
3000GT56 3000GT56 is offline
Please Answer this if you know the answer
I bought a 95 3kgt and the trans went on it. so i decided to replace the trans on it. when i got the trans put it we found out the engine went so i bought a engine from canada. MY MECHANIC IS TELLING ME THAT IM GOING TO HAVE TO BUY A NEW TRANS OR EVEN A NEW COMPUTER. WHAT I WOULD LIKE TO KNOW INSTEAD OF REPLACING THEM WHICH THEY ALREADY GOOD IS THERE A WAY TO HOOK UP A CANADIAN 3KGT ENGINE UP TO A U.S ENGINE?? PLEASE HELP I NEED ASAP
Old 08-02-2007, 10:36 PM
Igovert500's Avatar
blue + red light magnet
Re: Please Answer this if you know the answer
Find a new mechanic. Pretty sure canadian 3000gts have the exact same engine as ones from the states, so that shouldn't be an issue. Even if there are some small differences in sensors, etc...a half intelligent mechanic should be capable of making the changes. Regardless, find a new one, because if he couldn't tell the engine was blown before, then either he's incompetant or trying to make as much $$ off you as possible.
Ask to find out exactly what is wrong with everything he is telling you to replace.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 08-02-2007, 11:18 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
do you have an Auto or Manual trans? it sounds like you have an Auto because they are controlled by a computer, referred to as the TCU (transmission control unit). the Manual trans has no computer, its only controlled by the clutch pedal and the shifter .
so if the above is true that you have an auto trans, your mechanic doesn't know if the TCU or the entire trans is bad. ask him to tell you specifically what is wrong, because it sounds like since he doesn't know anything, he's just telling you to replace the whole thing instead of fixing the small part that causes the problem.
that's backyard/redneck mechanics for you, right there. morons who don't know how to troubleshoot and diagnose problems just tell you to replace the entire thing instead of repair the problematic part. both fix the problem, but one way is a cop-out and very expensive, and the other is the intelligent and right way to do it.
i agree with Igovert500. if your mechanic didn't know the engine went out until after he pulled the trans, then you should get a new mechanic. so lastly, please tell us all about your car (turbo or non-turbo, manual or auto trans, etc etc) and get the mechanic to tell you EXACTLY what is wrong. the more info you give us, the better we can help you.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 08-03-2007, 12:02 AM
its a 95 Automatic base no turbo... its a new trans and a new motor.. the trans came from colorado and the engine came from canada.
Old 08-03-2007, 06:33 AM
quackmandude quackmandude is offline
dude it should be no problem for the mechanic, the old computer should work fine if its an auto one, should plug right in. ur mechanics wack dude.
'94 3kgt SL
-ebay intake (why not)
-2 1/2 inch straight pipe exaust, custom y downpipe
-Ignition mods
-dual magnaflow exaust
-going TT (wish me luck)
black book
-'95 mustang v6 (modded) /////
-'00 neon (modded/non-turbo) ///
-'04 eclipse GT
-'05 eclipse GT (modded)
-'97 Prelude vtec (modded)
-CRX (modded)
-Mazda Miata mx5 //
Old 08-03-2007, 03:24 PM
hawk362's Avatar
hawk362 hawk362 is offline
Simply your mechanic is
A. Crook
B. Moron
C. A hot blonde
D. All the above
ATX 95 Base 3000GT
Off brand intake, 3sx downpipe, test pipe, custom catback exhaust, 3sx underdrive pulley, NGK PLUGS, lamborghini doors, 18 inch black rims, limo tints, GTR HIDS, Alpine in dash dvd screen,
100 SHOT OF ZEX WET NITROUS KIT
Old 08-03-2007, 03:37 PM
if the answers c, then stay with her, but not for ur car
'94 3kgt SL
-Ignition mods
black book
-'04 eclipse GT
-CRX (modded)
-Mazda Miata mx5 //
Old 08-03-2007, 03:45 PM
hawk362's Avatar
Lol
ATX 95 Base 3000GT
