Old 11-11-2002, 02:35 PM
Fishcat37's Avatar
Fishcat37 Fishcat37 is offline
Send a message via AIM to Fishcat37
Question Z6 swap - Tech Question
Ok, to start off- yes i did a search. I also have read many threads on Z6 swaps in rexes too. I might be getting an 89 CRX HF (MT of course), and I want to do a D16Z6 SOHC VTEC swap. 89-91 Si trans, P28 ECU (OBDI), and hopefully the GReddy turbo kit w/ fmic. I dont want to use the PM6 w/ a VTEC controller. I want to do it right w/ the P28 and run OBDI. The thing that im confused about is the wiring and OBDI. If I got the Entire 5G EX wiring harness and the P28 ECU, would i need one of those OBD0 to OBDI conversion harnesses? I dont think that I would, but Im not 100% sure. If anyone knows for sure please let me know....thanx in advance
FLINT BLACK 1990 CRX SI
Appearance Mods:
-JDM EF8 CR-X SiR Spoiler
-94/95 Integra GS-R rims
Performance Mods:
-JDM B18C swap
-OBD1 conversion
-Chipped P28 ECU
-Skunk2 Intake Manifold
-DC Sports 4-2-1 Header
-MSD SCI-L ignition
-EXEDY Racing Clutch
Interior Mod
-'95 Integra GS-R Gauge Cluster
Former Motors - RIP:
-JDM B16A #1- Blew up due to over-revving
-JDM B16A #2 - Hydrolocked
Former Cars
'89 CRX Si - "The Bumblebee"
'94 Integra GS-R
'96 Camaro
Old 11-11-2002, 02:55 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
i know this isn't the answer you're looking for but...it needs to be said. i say skip the conversion and get a wiring harness. i have heard so many people ruin their car's harness trying to convert it. it's worth every penny of the $150 to just extend 8 wires and the rest is plug and play.
half way through my swap we discovered the dizzy rotor was busted and of course nobody had one in stock on a sunday. so mine ended up the rpm switch route whenever i get around to turbo i'll go back to p28....waaaay better route.
i know the pics are big...sorry...but gves you a good view of the conversion harness
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 11-11-2002, 05:23 PM
Fishcat37's Avatar
thanx ami I'm on Honda-Tech a lot, and there's a guy over (blown90hatch) there that sells those for like $150. Your pics look just like his...maybe that is his...lol Anyways, I agree w/ you that it is well worth the $150. Someone on H-T gave me a very good link on how to do the OBD0 to OBDI conversion- it is: http://www.geocities.com/kurtsi_on/page7.html I cant believe that the wiring for this swap is more complex than the B16 wiring (4 wires added to stock harness plus a ground)...well, actually i can- since you are upgrading to newer electronics w/ different plugs. thanx again ami
Appearance Mods:
Performance Mods:
-JDM B18C swap
-OBD1 conversion
-Chipped P28 ECU
-MSD SCI-L ignition
Interior Mod
Former Cars
'94 Integra GS-R
'96 Camaro
Old 11-11-2002, 09:19 PM
amy@af's Avatar
no problem!
the guy i got mine from is named jason ([email protected]) i have sent several people to him...they were all happy.
good luck with the wiring should you chose to attempt it
Old 08-03-2004, 10:05 PM
jadaba jadaba is offline
Re: Z6 swap - Tech Question
hey check it out. I have a 89 hf with a zc v-tech in it and got the conversion harness for the ECU but i need help. there are some wires that i cant figure out how to convert IACV, the MAP, and the thermostat sensor. If you can help please do do
Old 08-03-2004, 10:06 PM
is there any one that can help
