Old 08-02-2007, 04:11 AM
sgniogs sgniogs is offline
04 Z71 with K&N filter kit
I put a K&N filter kit on my 5.3 Silverado. The loud noise when the air enters the intake is annoying. (Most people on here have commented on the same problem).
My major problem is it seems to flood the engine when I "get on" the gas. The noise it makes makes it sound as if the truck is really moving, but it just doesn't put out the power.
Is this common? Should I have someone readjust the computer?
Any comments are appreciated.
Old 08-02-2007, 08:27 AM
taillight taillight is offline
Re: 04 Z71 with K&N filter kit
Put the old system back on. You will have less problems.
Old 08-02-2007, 09:45 AM
777stickman 777stickman is offline
With the K&N it does make noise. Also the filter should be taken out of the bag and allowed to air dry for a couple days before installing it. Lots of posts about the excess oil messing up the MAF. Also you may want to disconnect the neg batt cable for about an hour so the VCM can relearn the new intake system.
I've had all that stuff on my '98 Burb and have put it back to stock with much better results than the after market stuff especially using an AC-Delco filter.
Hope this helps.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 08-02-2007, 11:52 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
As Taillight said for less problems.
I would also suggest.
Put the K & N filter behind the rear wheel and drive over it.
Then clean your MAF sensor and put the AC delco OEM air filter set up back on it.
MT
MT
Old 08-03-2007, 12:01 AM
thanks for the input. i will probably do as ya'll say and replace the filter with the original. it actually made my fuel mileage worse. that is the only reason i installed it.
Old 08-03-2007, 08:53 AM
MT-2500's Avatar
AF - Advisor
Aslo on a 5.3 always .
Take a look at the fuel pressure regulator.
Check fuel pressure and pull vacuum off and look for gas in vacuum line.
MT
Old 08-03-2007, 11:48 AM
n8zdogg n8zdogg is offline
I've K&Ns on several street vehicles and never had a problem, however I've not done the entire intake, just the filter element which I spray with K&N oil. What's this soaking dripping oil messing up Mass Air Flow sensors??
