Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 08-02-2007, 02:03 AM
spawn1017 spawn1017 is offline
Trans/ Cruise Control problem
ok, driving on nj turnpike at around 75, i was setting the cruise control and the the trans went into passing gear. After that, the car started bucking only when cruise was on. now, the speedometer barely works, it was jumping constantly, and now it doesnt work. Now the check engine light is on Any help????
Old 08-02-2007, 11:33 AM
reekor reekor is offline
Re: Trans/ Cruise Control problem
Check the connection at your speed sensor, if okay change the sensor.
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 08-02-2007, 12:24 PM
Thanks... where is the sensor located
Old 08-02-2007, 07:39 PM
On the drivers side of the transmission there is a wiring harness plugged into it. Sort of looks like a round tube sticking out the side of the transmission. make sure you dont force the bolt when removing it, they tend to get a little rusty you dont want it to snap.
