Old 08-01-2007, 06:51 PM
SavageAddict SavageAddict is offline
2002 Help with AC/Heat Control...
Hello,
I have a small issue with my 2002 Grand Caravan, the temeture control for the driver side does not seem to switch to cool all the way. I have the manual type controls with the split slider.
The passenger side will blow cold air but the driver side will not. Any ideas how to fix this?
It will go to full heat but not full cold....
Thanks in advance!
Old 08-02-2007, 02:40 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: 2002 Help with AC/Heat Control...
The ventilation system may just need to be recalibrated. Try one of these procedures: http://www.allpar.com/fix/codes-climate.html
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 08-05-2007, 09:13 AM
Non of those fit the Climate control in my van. I have 4 buttons and 3 knobs with manaual sliders.
I did check the actuators and they appear to be moving the blend doors all the way in both directions.
Any ideas? Is there a heat valve that may not be closeing? It's odd that it's colder on the passenger side then the diver side.
Old 08-10-2007, 01:19 PM
humphreys405 humphreys405 is offline
I had my '02 T&C at the dealer yesterday for this same issue, as my local mechanic verified that all four blend doors are working well and couldn't get any farther with diagnostics - thus it went to dealer.
The dealer said that the condenser is leaking and that the freon is low. Apparently, there is also a heater core on the driver's side which affects that side a bit (makes it warmer) AND the evaporator is cooled from the passenger side first. So problems compound and they want to replace the condenser.
I don't like $1,000 repair quote so will investigate further. I plan on recharging the system with 134 w/ leak fix and dye so perhaps I can stem a small leak if there is one and see a large one if it is there.
They said it was a known issue with condenser inlet pipes leaking . . . I'll watch this thread and post more as I work on it this weekend.
Best of luck to you on yours - if you find more please post.
BTW, I tried the reset codes page referenced above a month or so ago and couldn't find mine . . . I'l look again.
I have auto climate control, if that makes any difference.
Old 08-10-2007, 08:33 PM
vipergg vipergg is offline
Don't know but it sounds something like this.
Make : DODGE Model : CARAVAN Year : 2002
Manufacturer : DAIMLERCHRYSLER CORPORATION
Service Bulletin Num : 2400702 Date of Bulletin: AUG 05, 2002
NHTSA Item Number: 635697
Component: VISIBILITYEFROSTER/DEFOGGER SYSTEM
Summary:
SUBJECT REGARDING AIR CONDITIONER TEMPERATURE DIFFERENTIAL (STRATIFICATION) BETWEEN LEFT AND RIGHT FRONT PANEL OUTLETS. *TT
Check to Request Research. Submit below.
Old 08-11-2007, 11:37 AM
It sounds a lot like that! How / where can I get the text of the bulletin?
Thanks
Old 09-10-2007, 11:31 AM
More investigtion has revealed that while I may indeed have a small refrigerant leak the bigger issue is that the driver's side is always trying to heat and the passenger side has no heat.
On vent only (why didn't I try that before?!) the passenger side brings in normal outside-temp air but the driver's side is HOT (but, of course, not always!)
On full heat settings, driver's side shows no change in temperature and neither does the passenger side! Passenger side is not heating at all.
So, off to search these forums some more for "heater" issues. I've seen a few threads in that vein . . .
Best of luck to all.
Mark
