Old 08-01-2007, 05:08 PM
harmankardon35 harmankardon35 is offline
a/c compressor high pitched squeal
I have this high pitched "cutting glass" sound from my A/C compressor when the a/c is OFF...when i turn it on and the pump kicks on the sound disapears. It was there a month ago and I soaked some spray-oil in arounf the crack between the inner and outer part of the a/c and it shut it up until now. My guess is bearing, wonder if I should soak it again?
Old 08-01-2007, 05:35 PM
dizzle1's Avatar
dizzle1 dizzle1 is offline
Re: a/c compressor high pitched squeal
I gotta admit I have the exact same problem as we speak nice and quiet with AC on and cuts broken glass when off, never got into it yet need help
00 Intrigue
Old 08-02-2007, 03:14 PM
RUIntrigue'd RUIntrigue'd is offline
It's a bad compressor clutch bearing in the pulley. When the A/C is off, the pulley spins free (or is supposed to), when the A/C is running the clutch and pulley are locked together, so the noise goes away. Have the clutch bearing replaced and the noise will go away.....
2002 Intrigue GL
1970 AMC AMX, 390 4spd
1970 Mark Donohue Javelin, 390 auto
Old 08-02-2007, 06:29 PM
LittleHoov's Avatar
LittleHoov LittleHoov is offline
Send a message via AIM to LittleHoov
Yep, I have it as well, its a common problem with our compressors apparently. I havent done it yet because im cheap, my AC still works, and the compressor is a PITA to get too, and I dont want to remove it.
2000 Oldsmobile Intrigue 3.5 DOHC V6
Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners
1986 Jeep Cherokee 2.8 V6
Old 08-03-2007, 10:25 PM
well, i took a bottle of oil and put it in the crack between the two pulleys, trying my best to keep it off the belt, and it shut it up again so i think that may be a temp fix. On another note, i just topped up my a/c and i can see my breath! woo! I just baught the kit at the autoparts store that you attach the the low side a/c line and have it suck the can into your system. Before i had the hot drivers side and cool passengers side problem, now the passengers side it ICE cold and the drivers side is just cool. So theres still something going on there im not sure...all I know is it seems like a VERY common issue.
