Old 08-01-2007, 12:41 PM
GTPSPEED GTPSPEED is offline
BOSTONjoe98gs
quick question about boost gauge connect
ok guys well i was reading on here and someone i think it was bob or someone who gave me a link to step by step how to hook up a boost guage and where to tap into...the pic showed an elbow under the supercharger and it said to get a T connection and tap into it there...ok here the question i looked at mine and i already have a T connector there and both are being used. So i dont get it why would i have a T connection already and both have plasic tubs leading somewhere under the sc and one goes towards the back of the sc...is this normal?. ~joe
2000 GRAND PRIX GTP RED 14.345 @97.8mph
ubend delete
3in jimmyC downpipe
magnaflow high flow cat
Joeflo CIA (made it myself)
free bypass mod
3.4 pulley from zzp
Gates premium belt
1 step colder plugs
zzp PCM
ss 409 xl turbo mufflers
Old 08-01-2007, 07:48 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: quick question about boost guage connect
doesnt your driver information center have a boost guage already?
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 08-01-2007, 10:23 PM
BOSTONjoe98gs
Hahah yeah but it sucks..its a digital dash line...I want one that shows how much boost by the number..But other than that i wanna know why in the tutorial there is an elbow on that gtp and they say get a T connector...well my point of the thread is why does mine already have a T connector and both ends are already used. What else could that be? hmm
ubend delete
3in jimmyC downpipe
free bypass mod
3.4 pulley from zzp
Gates premium belt
1 step colder plugs
zzp PCM
Old 08-02-2007, 08:13 AM
BNaylor's Avatar
BNaylor BNaylor is offline
As pointed out technically it is not a boost gauge but indicator. More like a gimmick. It does not give you an accurate representation of boost numerically, especially when running mods like an undersized SC pulley.
Check to see what it is connected to. Maybe the prior owner added them. Also, if not used make sure they are capped off. Really doesn't matter because you can add another tee connector for the aftermarket boost gauge. The tee allows you to tap in to the main vacuum line with a one way output to the gauge. You are not limited to how many you install. The important part is the MAP vacuum line must be used for any aftermarket vacuum operated boost gauge.
Timeslip 08/12/06
AF Community Guidelines
