Old 08-01-2007, 09:22 AM
stick64's Avatar
stick64 stick64 is offline
Solutions for Bad GM Parking Brake Design?
It has been well documented that GM dropped the ball on the design with their parking brakes on 1999- 2003 trucks. Has anyone come up with a fix or a better way to prevent an ongoing maintenance issue with the parking brake? Hard on the pocket book having to replace rear rotors, pads, e-pads, etc… consistently.
Old 08-01-2007, 10:37 AM
chuck16's Avatar
chuck16 chuck16 is offline
Re: Solutions for Bad GM Parking Brake Design?
Hmmm. I guess having only had my truck for 3 years i haven't seen the wear yet. I did all 6 brakes 2.5 years ago and they are all in great shape still.
So I can't say that my ebrake system has any problems with it. My ebrake hasn't worn a bit and nor should it. It should only be in contact when it's applied; if it's in contact more often than not then perhaps an adjustment is required???? Just my worth.
2008 GMC ACADIA
SLE Edition, 7 passenger model
I AM Canadian!!
Old 08-01-2007, 11:49 AM
stick64's Avatar
Chuck, you being one of the fortunate ones. There are people that do not even realize their parking brake does not work until taking it in for state inspection. Some cases of wearing out after 15k miles. For some reason the e-brake would come in contact with rotor without drivers even knowing. I would be one of those.
Old 08-01-2007, 12:17 PM
chuck16's Avatar
Dude that sucks!
I must admit when I bought the truck that was one of the things i didn't test. When I put it all the way to the floor and it didn't grab I was worried. So, after inspection mine too were worn right down. So i backed the adjuster right down and put new shoes in and all was well.
Sorry to hear of your woes...
2008 GMC ACADIA
I AM Canadian!!
Old 08-01-2007, 12:31 PM
stick64's Avatar
So Chuck, no driver's side rear rotor issues upon you replacing pads??
Old 08-01-2007, 01:23 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
That explains why we here at work have a '99 and an '02 and niether one has working parking brakes. I was unaware of a faulty design.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 08-01-2007, 03:14 PM
maxwedge maxwedge is offline
A990 racer
Correct, that is why the new trucks have rear drums, the update kit on the parking brake hardware is still ineffective!
Old 08-01-2007, 03:19 PM
fillupread fillupread is offline
I removed the auto adjust on mine and do a manual adjust every so often and mine have lasted 150,000 miles!
Old 08-01-2007, 07:09 PM
TexasF355F1's Avatar
TexasF355F1 TexasF355F1 is offline
Send a message via AIM to TexasF355F1
I never had to replace mine. My mechanic just tightened it up and all was well.
I did always notice how the line rubbed up against the hanger bracket.
*Under Construction - New sig to debut*
Old 08-01-2007, 08:33 PM
rjeffery rjeffery is offline
I thought I was going to have to replace mine when it failed inspection, even bought the shoes. Turns out I was able to adjust it at the shoe.
2002 1500 Ext. Cab 4.8L 2wd.
K&N FIPK, Cat Back Exhaust, Rancho RSX Shocks, Silverstar Headlights High & Low, Infinity Reference Door Speakers & 10" Dual Voice Coil Sub. 265/75/16 BFG AT/KO's, Spray-In Bed Liner, Hella FF75 Fog Lights, Hella FF75 Driving Lights.
Old 08-02-2007, 02:10 PM
silverado122775's Avatar
silverado122775 silverado122775 is offline
There was nothing left of my e-brake shoes on both driver and passenger sides. They even cut into the rotor. I ended up replacing the rotors, e-pads and reg pads. now all is better Now I do not have worry about relying on the parking pin when parked on a incline.
2000 Silverado Z71, 5.3L, K&N GenII Air Intake, Y-pipe Exhaust (no muffler), Bosch Platnium +4 plugs, 242k miles and still running.
Old 08-02-2007, 05:43 PM
stick64's Avatar
How much did this set you back ??
thanx
Old 08-02-2007, 07:16 PM
thanx
I bought sloted rear rotors and brakes for about $250. the ebrakes are $90 a set from the dealer. Total about $340 and I did all my own work.
Old 08-03-2007, 07:03 AM
jem270's Avatar
jem270 jem270 is offline
I've got about 55000 miles on my 2003. It is an extended cab 1500 silverado with 5.3 engine. I still have origional pads on it. It stops well and the emergency brake works fine. This is the first I heard of this problem. Does the emergency brake have a separate pad from the regular disc pad?
1997 Grand Prix SE, 3.8 (L36), 4T60-E (auto) M13
2002 Grand AM SE1, 3.4 (LA1), 4T45-E (auto) MN5
2003 Silverado LS, 5.3 (LM7), 4L60-E (auto) M30
1988 Ford Bronco EB 5.0 (AOD) manual BW1356 & hubs
Old 08-03-2007, 07:49 AM
The e-brakes are separate pads. The rear rotors are drumed and disked. The e-brakes look like a horse-shoe and are applied like a drum brake pushing out against the inside of the rotor.
Then you have the regular brakes that are disk brakes that work like the front brakes.
