Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 07-31-2007, 10:52 PM
strangerinthemidst strangerinthemidst is offline
Send a message via AIM to strangerinthemidst Send a message via Yahoo to strangerinthemidst
95 Grand Marquis losing oil?
About 2000 miles after I get an oil change my oil light will start coming on. It doesn't stay on, but it flashes, usually when I'm on the brakes. I don't have any visible leaking, no stains on my driveway. The car doesn't smoke so I don't think it's burning it.
Where is the oil going???
About 2-3 years ago I had a 96' sedan deville and it did this to me. The car eventually blew a head gasket and it wasn't worth fixing.
Could that be what is happening to my car now?
Old 08-01-2007, 07:23 AM
HEMIDAZE's Avatar
HEMIDAZE HEMIDAZE is offline
Re: 95 Grand Marquis losing oil?
There is no magic for dissapearing oil. It is either leaking it or burning it. With no traces of oil on the motor, it is probably burning it. Don't expect a cloud of freight train smoke. Look for black on the inside of your exhaust pipe or some smoke may be seen by having someone follow you down the road and watch your exhaust.. Whatever the problem is, a light indicates no pressure so you would be wise to keep it topped off before the light comes on.
HERS---> 2006 Grand Marquis GS (replaced my 1998 w/cracked manifold)
HIS----> 2003 Dodge 1500 HEMI QC 4X4
Old 08-01-2007, 07:27 PM
So if it's burning...how can I get it to STOP burning?
Old 08-01-2007, 09:09 PM
HEMIDAZE's Avatar
Overhaul the motor. On a cheaper note, sometimes thicker oil helps.
Old 08-01-2007, 09:51 PM
what does overhaul the motor mean? work with me here, im a girl, im tryin to learn
next time I get my oil changed I'll try 5w30 instead of 5w20 and see what happens.
Old 08-02-2007, 05:37 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Ford/Mercury states that up to 1 quart of oil consumption in 1000 miles is an acceptable usage. I don't agree with that, but that is their stance. So you amy not have a problem after all. How much oil does it take to top it off? It could be that the sending unit is bad causing the light to flash on. Let us know.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 08-02-2007, 07:43 PM
Funny u say 1 quart per 1000 because after 2000 miles its 2 quarts low.
and to HEMIDAZE: I checked the exhaust pipe and there is black sooty stuff in it (kinda like wiping your finger in a fireplace), but a friend of mine said as long as its sooty and not oily, then its not an oil problem. I had someone follow me today and no smoke, EXCEPT when I floor it. Let me know your thoughts on that.
Thanks in advance.
Old 08-02-2007, 09:04 PM
HEMIDAZE's Avatar
Black sooty stuff would be from burning oil.
Old 08-02-2007, 10:27 PM
ok thanks. i still use 5w20 because thats what the owners manual says but im gonna try the thicker oil like u said before first and see how that works before i do anything else.
appreciate it
Old 08-03-2007, 07:47 AM
HEMIDAZE's Avatar
If it was mine I would try 20W50. It would definately help an engine old enough to burn oil. You might also go to your local auto parts store. They sell oil additives specifically for motors that burn oil.
Old 08-03-2007, 10:16 AM
I'll try that. Thanks
Old 08-05-2007, 03:25 PM
kevin23 kevin23 is offline
Hemi, isn't the 20-50w oil way to thick for the fine oil screen in these engines?? I won't go above 10-30 in mine.
Old 08-06-2007, 08:57 AM
miamibob's Avatar
miamibob miamibob is offline
I would try the additives but other than that I would fix the REAL problem and not use real heavy weight oil. MB
Old 09-07-2007, 06:58 PM
ok im at a complete loss now
Been 3000 miles and my ALL of the oil was gone. There wasn't anything on the dipstick. I had them look for leaks and there are no leaks. I had them put in 10w30 and see how that works, but I'm doubtful.
Is it possible that all of my oil (5w20) could have burned up that quick???
If it's not burning...could it be leaking somewhere they can't see?
Old 09-07-2007, 08:11 PM
way2old's Avatar
TOKEN HILLBILLY
Have you checked or replaced the PCV valve? Possibly it is hung and causing the engine to suck oil vapors and causing the loss of oil. I don't think it would cause that much loss, but it is something worth looking into.
