Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-31-2007, 10:52 PM
baritonejim baritonejim is offline
Coil replacement in distributor
My son's 91 Lazer (1.8L engine) won't start - it has no spark, the resistance throught he coil does not meet the specs, so we are trying to put in a new coil. But, I'm having trouble getting to the old coil which is inside the distributor. The screw inside the rotor socket won't turn without stripping. Does this screw operate backwards from normal, or is there another trick to geting to the coil? Thanks in advance for your help.
Old 08-01-2007, 10:51 AM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
Re: Coil replacement in distributor
I'm not a 1.8L guy, but let's see if I can help.
The Distributor cap (sits on top)
This distributor cap has the coil built into it(from my understanding)
Underneath the Distributor cap(ignition coil) sits the Rotor button. These are usually held on by a screw.
Then this is the distributor itself.
Now, In regards to your post, I'm not sure exactly what you're meaning. Please give me some pics or explain a little more what you're meaning.
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
Old 08-03-2007, 01:06 AM
It's complete thanks to some help from a friend and his mechanic father. You do not have to take the gear off the shaft, in fact it won't easily come off at all. The screw on the top of the shaft turns in the standard direction but is very tight, probably from the rotation of the shaft. It took an expensive flat screw driver that perfectly fit the slot with zero play and a large handle and a lot of muscle to get screw off of the top of the shaft of the distributor and gain access to the coil.
