Old 07-31-2007, 09:45 PM
carguyvr4 carguyvr4 is offline
Send a message via AIM to carguyvr4
I Need Hel Asap
Hey so the other ngiht my car decided to loose power and die out on me ... it was running fine all day and then all of a sudden while driving my radio cuts out and then the lights go dim.. as i drove it and kept the rpms up the lights got brighter and it ran but then when slowing down and coming to a stop the would go dim and it would die... sounds like the alternator so i replaced it and still the same porblem everything goes dead and it wont start.. i jumped it and it'll run but then die.. its not charging... any ideas what i can look at to find the problem im running outa ideas.. battery is fairly new
Old 07-31-2007, 09:55 PM
X2Xtreme360 X2Xtreme360 is offline
Re: I Need Hel Asap
def sounds like the alternator to me. A cheap way to test your alternator is to start the car and disconnect the terminals from the battery. If the car remains running then it's your battery. Your car should run fine with a bad battery but the lights would go dim.
Current mods:
Cold air intake
Magnecor 8.5mm competition wires
NGK copper spark plugs
Polished Plenum
KillerGlass radiator hose
Old 07-31-2007, 10:11 PM
Re: I Need Hel Asap
yea i'll try it idk what else could be the problem its prety weird i jstu spent 300 on belts n alternator n now its not fixed
Old 07-31-2007, 10:20 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: I Need Hel Asap
Make sure the altenator fusible link isnt blown. Its in the underhood fuse box in the corner closest to the passenger fender. Its bolted in but should have a clear top. Also check the wiring that goes to it where its bolted in. Wire should go from the battery, to that fusible link, to the altenator. If its broken anywhere along the line the alt cant charge the batt.
Old 07-31-2007, 10:26 PM
Re: I Need Hel Asap
The one where all the fuses are for liek the battery and stuff or somewhere else?
Old 07-31-2007, 10:29 PM
Stealthee's Avatar
Re: I Need Hel Asap
That would be the one. It has fuses and relays in it. Next to the passenger headlight.
Old 07-31-2007, 10:32 PM
Re: I Need Hel Asap
yea they all seemed to be ok the ones for the alt n battery anyway....
Old 08-01-2007, 09:21 AM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
Re: I Need Hel Asap
Have your battery tested also. It is something with your electrical system either not putting out enough power or drawing too much.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 08-01-2007, 08:09 PM
Re: I Need Hel Asap
Alright so the battery is holding a charge and the alternator was tested n bad.. so its replaced and the problem is still happening? the clear fuse ohms out like it should so tahts not the problem where could it be drawing too much from?
Old 08-02-2007, 01:01 PM
new2mitsu new2mitsu is offline
Re: I Need Hel Asap
did you buy a new alternator, or a used one?
Old 08-02-2007, 04:28 PM
Re: I Need Hel Asap
New they tested it for me on the spot to make sure it was good... we recharged the battery and now the batt by itslef can hold a charge but once in the car it jsut gets drained in a matter of 5 min or less it goes from 12v ta below 9 n stalls out the car.. the fuse for the ALT. is good (the clear one they call a fuseible link) that ohms out good and the wires are all carrying volatage... I'm kinda running outa ideas
Old 08-02-2007, 04:42 PM
Re: I Need Hel Asap
Are the battery cables hot after you put it in the car. If it is drawing enough current to drain the batter that fast the battery and cables would probably get hot. If not I would still bet on your battery not being able to hold 12v under load.
Old 08-02-2007, 07:02 PM
Re: I Need Hel Asap
BUt i bought a new batt. and the same thing still happened.... the alternator was tested at the place and tested good i took the old one there it tested bad.... the relay is fine all the fuses are good... while raising the rpms the batt. voltage went up then once off the rpms it goes back down n dies....when i turned the car off the volt meter read 11.2 running and when off its spiked up to 11.6 where could i be drawing that much power from while running.. radio a/c lights all that are off durring this time....any ideas... my next step prolly 2morrow is to run the car and jsut pull fuses to see if a certain system is pulling a load that cant be handled....I'm running out ideas
Old 08-02-2007, 09:03 PM
Stealthee's Avatar
Re: I Need Hel Asap
If thats all the voltage youre running then the alt is NOT charging. Check ALL wires going to and from the alt and the battery.
Old 08-02-2007, 09:18 PM
3000GT56 3000GT56 is offline
Re: I Need Hel Asap
check the ground from the engine to the chassis i had the same problem so i took the ground wire from my amp and fixed the problem
