Old 07-31-2007, 09:29 PM
9997matt 9997matt is offline
97 5.7L wont start
hey im new, i made this to get help with my truck. I have a 97 5.7l that wont start. Im getting spark and fuel. I replaced the distributer cap and roter and igniton coil. still no luck. fuel pump engages, there is pressure, when i try and start it wont turnover. once every three or four times u can hear a loud pop or air being sucked in through the air box. any help would be greatly appriciated.
Old 08-01-2007, 08:42 AM
taillight taillight is offline
Re: 97 5.7L wont start
When you say it will not turn over do you meam the engine will not crank or it will not fire?
Old 08-01-2007, 05:49 PM
it wont fire
Old 08-01-2007, 06:48 PM
2000CAYukon 2000CAYukon is offline
Fuel pressure needs to be 60 - 65 PSI to start a Vortec.
What is yours at?
//2000CAYukon
Old 08-02-2007, 08:23 AM
Try spraying a little carb cleaner in while cranking. If it starts it's a fuel problem. Pull your plugs. If wet your flooded. Try new plugs. Check for spark. Some electric ignitions have problems firing plugs that ar flooded.
Old 08-02-2007, 05:21 PM
i tried what u said, sprayed carb cleaner in there no luck, pulled the plugs, they wernt wet,
Old 08-03-2007, 07:59 AM
Pull all the plugs and crank the engine over to clear out the engine. Put in new plugs.
Old 08-07-2007, 07:31 PM
i finally got around to that and it still wont start, i replaced the fuel pump, filter and strainer today just to come to the brick wall that it wont start
Old 08-08-2007, 08:33 AM
Do you have spark? Pull a plug wire and put it on an old plug and crank the engine.
Old 08-08-2007, 04:45 PM
i tried that before i replaced the fuel pump and i have lots of spark,
Old 08-09-2007, 08:14 AM
You need 3 things to run. Fuel, spark and compression. Do a compression test.
Old 08-10-2007, 01:12 PM
scoobytuff scoobytuff is offline
Is the spark and fuel that you are getting consistant?
Old 08-10-2007, 01:38 PM
trb333333 trb333333 is offline
When replacing the rotor is it put on correctly. is it possible it is on 180 degrees off. or if the distributor was pulled did it get put back correctly.
also did you put wires on and are they in the correct order and position...
on the cylinders but also on the distributor if not............
Old 10-02-2007, 09:20 PM
young_11_blood's Avatar
young_11_blood young_11_blood is offline
I have the same problem. I have replaced all my sensors as well. Some people have told me that the computer on the vehicle could get jarred or some electrical connections could have loosened
