Old 11-11-2002, 12:57 AM
concept_51 concept_51 is offline
Question engine B series
hi guys.....im new here and i would love to get some help ard here
is there any recommendations on engine scratch building....i would like to have some directions in building B series engine for civics
CHEERS
Old 11-11-2002, 01:02 AM
integra818's Avatar
integra818 integra818 is offline
Send a message via AIM to integra818 Send a message via Yahoo to integra818
Building a b-series engine from scrath will be a pain-in-the-ass, buy a revell integra and use that engine, or wait for the revell civics in january( I think)
Old 11-11-2002, 10:37 AM
Lownslow's Avatar
Lownslow Lownslow is offline
january( I think)
Wrong O we wont get them till late spring well get the 3 door fist sometime around March its really staring to get me too if they delay it once more forget it ill get something else
Old 11-11-2002, 10:59 AM
integra818's Avatar
I don't mind the delay, If I baught them today, I would'nt have built them by march anyway, I have an integra to finish adna lancer and a skyline to start, I got plenty of time
Old 11-12-2002, 02:02 AM
hirofkd's Avatar
hirofkd hirofkd is offline
Re: engine B series
CHEERS
Start from four evergreen plastic pipe or rod, and add strip of plastic sheets on both sides to make a block. Add ribs with a piece of plastic, and various rods. You might also have to carve into the block with a very small chisel.
Still, the quickest way is to start from Revell's B18.
Hiroaki Fukuda
Old 11-12-2002, 02:26 AM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: Re: engine B series
For sake of a small model the only differnce in the engines is the intake manifold.
In real life the B18 is 10mm taller, and has a differnt intake and exhaust.
Otherwise the engines are visably very similar.
Old 11-12-2002, 10:45 AM
integra818's Avatar
Re: Re: Re: engine B series
True, I would like to add to this, the b16 can easily be converted to a b18 by changing the rods,pistons, and crank, which are not visable, the head is different too but you cant tell the difference by looking at it from outside, and the revell itr with the type r engine also has a type r maniford, which cant be bolted directly to a civic's b16 but a company called skunk2 makes a manifold that bolts to the b16, that is very identicle to the type r one, as a matter of fact, it's the same mainifold exept the bolt pattern, so if have that revell itr engine in a civic, consider it modified! BUt if you want it to look real, paint the manifold flat alluminum because the manifold in the kit comes chrome.
Old 11-12-2002, 04:23 PM
I dont understand why revell keeps stalling on their civics. When i first saw em on the site, they said they would release WAYYYYY earlier then what it says now.
Old 11-12-2002, 07:33 PM
hirofkd's Avatar
Because it's Revell.
Unlike Tamiya, who almost always ship a new item on the announced date, Revell rarely keep the said release schedule. That's the way they are. There was a company called Accurate Miniature, and they were even worth when it comes to time management. The company went out of business.
Hiroaki Fukuda
Old 11-13-2002, 01:43 AM
well done....u guys r good at engines
to be exact...the ITR B18C block is 8mm taller than a B16A
and yes the internals can be changed but alot more work like matching of the crankshaft and boring it to 84mm is to be done in a B16A. it is not as reliable as a B18C block as it isnt a reinforced one.
cheers to all enthusiasts
singapore
