Go Back   Automotive Forums Car Chat > Classic Cars
Classic Cars Do you just love the classics?
Old 07-31-2007, 08:07 PM
dakota9991 dakota9991 is offline
hesitates
289 with a 600 holly nice cam headers duel piont dist. with stock coil dist. has mechanical advance { no vac.} on take off it hesitates but once it rolls it runs GREAT its bolted to a automactic trans can anyone help thanks
Old 08-01-2007, 09:55 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: hesitates
It could be a lean spot in the carburetion, caused by the secondaries opening too quickly (if vacuum secondary, a firmer diaphram spring will correct this)
Also, the accelerator pump may need adjustment, to deliver a bigger squirt of fuel. I recall the plastic accelerator pump cam has 2 positions, and can be moved from one to the other for adjustment. Also, a larger set of 'squirters' can be installed. They screw in just above the primary barrel venturis.
