Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 07-31-2007, 06:40 PM
cranknandcrankn cranknandcrankn is offline
need a transmission pan
hopefully a simple question. I know jack squat about transmissions except that my pan is badly rusted and leaking. I know my transmission is a 46RE, I can find some good deals on a 727 pan, but im not sure if it would fit. It looks the same. so whats the difference?
1999 1500 5.2L Sport 4wd
99,000
Old 08-02-2007, 12:17 AM
RexNfx400's Avatar
RexNfx400 RexNfx400 is offline
Re: need a transmission pan
727 has same bolt pattern. But is not deep enough for the added valvebody thickness in your transmission... Sorry, won't fly.
Old 08-02-2007, 04:17 PM
what if the 727 pan were a deep pan approx. 2 inches deeper than a regular 727?
Old 08-02-2007, 05:28 PM
RexNfx400's Avatar
Thats cutting it pretty close.
If you used a transmission filter from a '89-'96 unit, you would have better luck. Because the filter is thinner. Though, then you have to find the correct bolt length for the added hole on the early filter
Then you still need to measure to make sure the filter isn't squished against the pan. Or you might not get enough volume of fluid for proper operation.
