Old 07-31-2007, 05:58 PM
ZAAACH ZAAACH is offline
1996 Park ave water pump
my waterpump went bad after 116k miles and when i went to change it all of the bolts came loose execpt for one that is located right behind the idling pully... how do u get the pully off and after the pully is removed, does the water pump come off easily?
Old 10-18-2007, 09:31 PM
mike mckay mike mckay is offline
Re: 1996 Park ave water pump
How did you get that pulley to come off? I'm having the same problem with my 95 park avenue, but I think it's the power steering pulley that's in the way of that last bolt.
Is the power steering pulley pressed on or is it bolted on???
Old 10-20-2007, 10:35 AM
Smith1000 Smith1000 is offline
If it is like the Lesabre, rotate the power steering pulley. There are access holes in the face of the pulley. Run a socket through the pulley holes to loosen the bracket bolts. They have to be backed way off to get enough room to remove the final water pump bolt.
