Go Back   Automotive Forums Car Chat > Pontiac > Sunbird/J2000/2000 Sunbird
Old 07-31-2007, 07:48 AM
ziggy1969 ziggy1969 is offline
Question replace oil sending unit
Hi there,
I really need some help with some tricks on how to replace the oil pressure sending unit.
89 Sunbird - 2.0 L OHC developed an oil leak at the oil sending unit which is located right behind the oil filter. So I picked up a new part. The space is soooo tight, I couldn't get a wrench in there. So I then picked up a 1 1/16" deep socket. But it doesn't fit in the space either.
So it now looks like I may need to start removing some additional components in order to try and get a wrench in there.
Any hints or tricks on how to get this part changed.
tia
Old 08-05-2008, 10:21 AM
rytntyt rytntyt is offline
Re: replace oil sending unit
Well, I just recently changed that little $%***(, and your right it is very difficult to get to. There is a bolt that sits right in front of the switch that you have to remove in order to fit a socket in there, and even when you have done that (it's doable) but it is still tight. Good Luck.
Sonny
Old 10-16-2008, 09:18 PM
clutch492 clutch492 is offline
ASE Master Tech
Smile Re: replace oil sending unit
I replaced mine. I was wondering how to get to it until I had the heater blower motor out of the car to do some cleaning on the heater core. I looked down,,,,,, and there the oil sender was,,,,,,,,,,staring me in the face. Got right to it and was able to change it fairly easy. Hope this helps.
Kevin Campbell
Kansas
Old 07-24-2010, 10:28 PM
Paul94Z28 Paul94Z28 is offline
I did mine from the bottom on my 1.8, no big deal.
