Old 07-31-2007, 07:05 AM
elenita elenita is offline
error p1537 98 windstar
my check engine light was on and my neighbor reconnected a vaccuum hose that was off when the light didnt reset i went to autozone and they scanned it and it has error p1537. is where is the intake diverter located?
Old 07-31-2007, 09:20 AM
Freakzilla69 Freakzilla69 is offline
Re: error p1537 98 windstar
That's your rear Intake Manifold Runner Controller. It's inside the Lower Intake Manifold.
The error code can be caused by either sludge built up inside the lower manifold, a faulty actuator (most likely) or a vacuum leak in the line goint to the controller.
It's a common problem and there's lots of topics here about it.
The bad news is that if your problem is the controller, they are about $200 a piece and you have to order the part. It's not something they sell at Autozone.
Old 07-31-2007, 09:26 AM
I forgot to mention...
As a temporary fix, you can rig the runner closed with wire or tie-wraps and the light will go off.
Old 07-31-2007, 09:54 AM
Thanks for the info, i guess i'll get the Chilton out of the library and attempt this, another adventure for me. thanks
Old 08-01-2007, 09:37 PM
wiswind wiswind is offline
It takes a certain number of "drive cycles" without a failure for the light to go OFF.
The computer will keep the code stored and the light lit for while.....even after the problem is gone.....to enable a diagnosis.......
In short, wait a while for the light to have a chance to go out on its own.....or clear the code (if you don't have a code reader.....disconnect the negative battery cable, wait at least 15 minutes, reconnect).
The problem with clearing the code this way is that it will remove the "driveability" information....which takes a while to relearn.....so you don't want to do this within a few weeks of going for a emissions test (if your area requires one) as they will get a P1000 code indicating that the OBDII system has been cleared......and they will not pass you until the system completely re-learns the information.
Don't run out and buy a expensive part that you may not need.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
