Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-30-2007, 10:53 PM
BIGBOOSTLV BIGBOOSTLV is offline
No Spark????
I have a 1990 talon tsi that is getting fuel and turns just fine, but not getting any spark. I just got this car a couple weeks ago and am not quite familiar with it yet. Where shoud I start diagnosing the issue?
Thanks
Dan
Old 07-31-2007, 07:37 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Re: No Spark????
Thanks
Dan
First off check your fuses. Then I would start by checking the spark plug wires and if those look good trace them back to the coil pack. If you have a haynes/chiltons manual it will tell you how to test the coil pack to see if it's good.
After you have done that come post here with the results.
1991 GSX 2.3 Stroker
Old 07-31-2007, 09:00 PM
KoDKingVegeta KoDKingVegeta is offline
Re: No Spark????
It could be one of two problems, 1: Coil pack is bad, 2: Ecu is shot. I had this problem with my one 92 Talon ES, first replaced the coil pack, and it ran for a few days then died again. Then I replaced the ecu and it runs fine now.
1989 Honda Civic DX Hatchback
*STOCK
Twisted Motor Sports
The Cell Games
^--Help Revive an old forum, Come Join
-=flash to the future: (three months) "As stock prices continue to climb for superglue... ppl are frantic.... *static* KoDKingVegeta buys the whole market out *Static* fix *static* dashboard from *static* UK... *end of flash to the future*=-
Old 08-01-2007, 01:53 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: No Spark????
To add to the list, the ignitor can fail as well. There is also a coil fuse, but I forget if they label it that plainly or not. The flow basically goes ECU Ignition Drivers>Ignitor>Coil>wires>plugs>ground.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
