Go Back   Automotive Forums Car Chat > Ford > Contour
Old 07-30-2007, 10:47 PM
chevyboy12921 chevyboy12921 is offline
Send a message via AIM to chevyboy12921
Question 2.0 liter zetec
what years did the 2.0 liter zetec come in the contours?
Old 07-31-2007, 04:18 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Re: 2.0 liter zetec
All years (i.e. 95-2000)
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 08-01-2007, 12:57 AM
Re: 2.0 liter zetec
thanks im looking to get a valve cover off of one for my focus
Old 08-01-2007, 03:05 PM
Re: 2.0 liter zetec
Considering the heads are different from the 2.0L in the contour and the 2.0L in the focus, im going to guess the valve covers are different.
"The CEG Nazi"
www.contour.org
Old 08-01-2007, 03:36 PM
Re: 2.0 liter zetec
valve covers are different i need the valve cover gasket for the contour but they are the same size and bolt patern so it should work
Old 08-01-2007, 03:39 PM
Re: 2.0 liter zetec
i want to paint my valve cover but i cant find any high temp paint for plastic so im gunns try a metal one from a contour
Old 08-02-2007, 12:46 AM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: 2.0 liter zetec
focus valve cover will work but you need longer bolts. and it will only work on pre98 (95-97)
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 08-03-2007, 12:39 AM
Re: 2.0 liter zetec
i want to put a contour valve cover in my focus not the other way around
Old 08-03-2007, 10:42 AM
Re: 2.0 liter zetec
either way, it sounds like the bolts arent interchangable. Sounds like your going to need shorter bolts.
"The CEG Nazi"
www.contour.org
Old 08-03-2007, 01:21 PM
pre98zetec's Avatar
Re: 2.0 liter zetec
then do what Jim said, use shorter bolts instead.
-Josh-
Old 08-03-2007, 08:52 PM
Re: 2.0 liter zetec
thanks guys, it fits and works(i just used the bolts from the focus valve cover)
Old 08-11-2007, 02:08 PM
blueredrider blueredrider is offline
Re: 2.0 liter zetec
1996 Mercury Mystique (Ford Contour) 2.0 Zetec
114,000 miles
upon inspection after my car died doing about 60 mph, I found
1. oil leaking (shooting) into air fliter...
2. oil shooting out of where you pour it in the engine (a lot of air pressure)
3. all 4 spark plugs are almost completely covered in oil
(only tip wjhere it connects to the wires are exposed above the pool of oil.
i don't know much about engines, but i must have some kind of oil leak...maybe a gasket or something
**any advice would be very helpful at this point to see what I can do
-Thanks
Old 08-12-2007, 01:41 AM
Re: 2.0 liter zetec
change the va,ve cover gasket
