Old 07-30-2007, 10:11 PM
joetikk joetikk is offline
hub bearing keeps making noise
i have a 99 taurus with 3.0 i replaced 4 hub bearings on drivers front the last one new 3 junkyard hubs one came off car that i heard run i put on car and the inside of hub snaps and when u turn right the car locks up slightly like ur pressing the brake can someone please help im tired of replacing hub bearings on this car
Old 07-31-2007, 11:03 PM
RickMN RickMN is offline
Re: hub bearing keeps making noise
Are you using an air impact wrench to remove and reinstall the axle nut? That can destroy a wheel bearing. Hand tools only!
I'm a retired ASE Master/L-1 Technician. I still keep current with the latest automotive technology.
Old 07-31-2007, 11:49 PM
yes i used hand tools and didnt torque them hard i used only little torque on axle nut is it possible the axle is defective or control arm bent
Old 08-01-2007, 11:58 AM
Well, that may be part of your problem. The factory spec on torque for the axle nut is 170-203 ft/lbs. That's a LOT of torque. My only caution was not to use impact tools.
If the axel isn't properly torqued to the hub, you will get a lot of noise. You need a pretty big torque wrench to reach up that far--one with a long handle for leverage.
Old 08-01-2007, 12:01 PM
i appreciate all the help i have done plenty of hubs on taurus,s this one car has me bogglede in three weeks the hub snaps i dont know were to go from here
i dont know were to go from here besides replace hub again then axle is this right choice
