Old 07-30-2007, 09:51 PM
nlranger nlranger is offline
no fuel spray on start
i got a 1993 cheyenne 4x4. the truck will not start without priming. i have to unplug iac prime and let idle for 10-15 minutes. after that i'am good to go. i can shut truck of and restart if i do not leave her to long. i changed fuel pump a couple of times. fuel comes to trottle body but will not spray without priming on cold start. i never checked fuel pressure. any help appreciated.
thanks
Old 07-31-2007, 08:31 AM
taillight taillight is offline
Re: no fuel spray on start
Check the fuel pressure off and at idle. Should hold pressure.
Old 07-31-2007, 08:47 AM
thanks for the reply taillight. so even what seems to be good gas flow at the trottle body. the pressure may not be there. correct? i do not see a place to check for pressure on top. i think its down under in a hard spot to get at. can someone let me know. thanks.
Old 07-31-2007, 08:57 AM
i forgot to mention that i bought a cheap codereader and got the following code errors 15,22,54
Old 07-31-2007, 09:03 AM
What engine? You may have to break into the fuel line.
Old 07-31-2007, 09:31 AM
v8 7.4
Old 07-31-2007, 09:50 AM
My book says there is a fuel pressure connector in the line. I don't know where it is but there is one
Old 07-31-2007, 11:33 AM
I found one on a 7.4 in an 98. The valve is on the front of the fuel rail.
