Old 07-30-2007, 07:14 PM
denmarjs denmarjs is offline
location for flasher on 98 voyager
For the life of me I can`t find the flasher for the turn signals,also have another problem air bag light is on cruise does work horn does work,I found a wiring harness under steering wheel witch a think is the problem yes I disconnected the bat,don`t need the air bag in the nose any help would be appreciated
Old 07-30-2007, 08:45 PM
earlyrizr earlyrizr is offline
Re: location for flasher on 98 voyager
under the dash just left of the steering column,is the fuse block and the flasher is mounted to it.square black block.
as for the air bag might be the clock spring for which there is a recall.
Old 07-30-2007, 08:54 PM
tempfixit tempfixit is offline
This link shows the flasher under the hood. http://www.autozone.com/az/cds/en_us...es.htm#hd1-1-4
Hope this helps.
Old 07-30-2007, 09:45 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
I'll be! Tempfixit - looks like another example of differences within the same generation. On my 96 the flasher (combination flasher) is located as earlyriser stated. Chrysler sure likes to mix it up don't they.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
