I recently bought a 1992 Camry DLX with 180k miles. So far the car has been great for the $2500 I paid. Here's the problem:
I've checked the GUAGE fuse (10A) and verified it is good. I will be checking the wire harness in the truck today to troubleshoot the backup lights. Any thoughts? -Scott
...because it feels so good when you stop!
Re: '92 Camry: Several lights out
Numbers 1 and 2 could be related. You are correct in checking for those 2 problems with the loom of wires in the trunk located by the driver's side trunk hinge. The wires in that loom have a tendancy to frey and break from all the flexing they are exposed to when the trunk is constantly opened and closed. Open up that loom of wires and look for freyed or broken wires. Repair as necesary. I can't help with number 3 but number 4 is probably just a burned out bulb under the consul. You can do a search on this forum for instructions on how to get to it and replace it. You can also download the generation 3 Toyota factory service manual stickied at the top of this forum for some help. Here's the link:
http://www.automotiveforums.com/vbul...d.php?t=497839 Mike |
#1, 2 & 4 are fixed. How can I tell if the shift-lock is actually working?
press the button and see if you can shift it out of park without having the brake pressed.
Or...troubleshoot using this excerpt from the Factory Service Manual at the top of the forum: http://www.turboninjas.com/camry/ax1.pdf Open it then scroll to page 36,37,38.
What fixed 1,2, and 4?
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds. **Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual. 07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan |
