Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 07-30-2007, 12:11 PM
klyl998 klyl998 is offline
need help with rear differential nut removal
i have 01 4 runner, needs to remove rear differential oil, the
filler nut is hard to remove, would you suggest using propane flame
to heat the nut, then turn it to open ? will that work
Old 07-31-2007, 07:26 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: need help with rear differential nut removal
I would be very cautious about heating that plug. You might crack the housing and then you have a real expensive repair on your hands. Try penetrating oil like Blaster and see if that helps.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 08-02-2007, 09:42 PM
silversup silversup is offline
PB blaster plus a socket and breaker bar.
Old 08-03-2007, 01:26 AM
legbreaker legbreaker is offline
I don't know what that plug is made of, but doesn't heat generally have a "swelling" effect on metal?
Old 08-03-2007, 01:49 AM
Brian R.'s Avatar
Resident Chemist
Yes, that was my problem. You would have to heat the housing and I don't like the idea. Never done it though. I would go the Blaster route and see if the penetrating oil allowed you to turn it.
Old 08-06-2007, 01:02 PM
curious to know what is PB blaster, i know if i fit a copper pipe over
the rachet and use hammer to move the nut.
Old 08-06-2007, 02:17 PM
Brian R.'s Avatar
Resident Chemist
PB Blaster is penetrating oil.
