Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 07-30-2007, 12:10 AM
cool_david2006 cool_david2006 is offline
Engine Code P0420
I have a 2000 Lincoln LS V8 with 91,000 miles on it. And it is reading the engine trouble code P0240. I had autozone check it out and they said it could be an O2 sensor, or the cats, or a misfire. I looked at the Valve cover gaskets and they look like they have been changed already. Also if it were a faulty O2 sensor, wouldnt it run rough? My Lincoln runs fine. Im wondering if it is an emission problem. I belive when I bought the car, the dealership used regular gas instead of premium gas. Could that have set this code off? Any advice would be much appreciated. Can I clear this code without going to a dealer? Oh yea, and I LOVE my Lincoln.
Old 07-30-2007, 08:16 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Engine Code P0420
I assume that the code listed in the subject is correct rather than the P0240 mentioned in the text of the post.
That being the case, as you are probably aware, the code definition is Bank 1 Catalyst System Efficiency below threshold. According to the factory service manual, likely causes are:
  • Use of leaded fuel
  • Damaged HO2S
  • Malfunctioning ECT
  • High fuel pressure
  • Damaged exhaust manifold
  • Damaged catalytic converter
  • Oil contamination
  • Cylinder misfiring
  • Downstream HO2S wires improperly connected
  • Damaged exhaust system pipe
  • Damaged muffler/tailpipe assembly
  • Retarded spark timing
Also per the service manual, you can verify the cause by the following:
Compare HO2S upstream and downstream switch rate and amplitude. Under normal closed loop fuel conditions, high efficiency catalysts have oxygen storage which makes the switching frequency of the downstream HO2S very slow and reduces the amplitude of those switches as compared to the upstream HO2S. As catalyst efficiency deteriorates, its ability to store oxygen declines and the downstream HO2S signal begins to switch more rapidly with increase amplitude, approaching the switching rate and amplitude of the upstream HO2S. Once beyond an acceptable limit the DTC is set.
-Rod
Old 07-31-2007, 09:16 PM
So im guessing its just a damaged or bad cat. seeing how it has 91000 nikes on it, its probley time to change them. Thanks for the advice.
