Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 07-29-2007, 11:23 PM
VLT VLT is offline
Help w/5spd shifting noises??
I have a 99 Wrangler TJ, 5spd...when shifting and sometimes when not, I hear a rattling, click/clack type of noise, possibly loose??? Is this normal for a Jeep and if not, what could the problem be?
Old 08-01-2007, 03:53 AM
Kuhn's Avatar
Kuhn Kuhn is offline
Send a message via AIM to Kuhn Send a message via Yahoo to Kuhn
Re: Help w/5spd shifting noises??
Well, if you are running 48's with a supercharged 4.0L and are nearing 250k mi... There could be a problem!! Otherwise, my guess is that it's chattering from the clutch, which on its own is pretty normal. In my Wrangler the chatter is worst while I'm idling and it's completely out of gear. But if it's doing that while your giving it a little gas, this could be the sign of a problem with the clutch... If it does this while cruising at 45 mph it could be anything in the drive train, or just your tire choice (causing vibration that sounds like something more serious). I'd recommend that you take it to a dealership... But maybe that's just because I have the extended warranty and the Mechanic at the dealership near me is the biggest Jeep nut I've ever met!
'98 Eclipse RS
ENGINE: Twin Ceramic Ball Bearing T3/T4 with ceramic blades (20G for sale!), FMIC, 3'' Intercooler Piping and Down Pipe, Dump after Down Pipe, Walbro 255 FP, 450cc 4G63 Injectors, Greddy E-Manage, TurboXS DSBC (4/7psi for now).
SUSPENSION: Sustec Front and Rear Lower Tie Bars, Suspension Techniques Front and Rear Sway Bars, DC Sports Front and Rear Upper Strut Tower Bars, Eibach Pro Kit Springs, KYB AGX Adjustable Struts, Polyurethane Bushings Everywhere.
