Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-29-2007, 09:45 PM
thisismylife thisismylife is offline
dont know
ok iv got a wired thing going on i have a 1990 eclipsegs 1.8 yaya i no the 1.8 are crap but when im at a stop and go to move when i let go of the clutch i go but it go in high rpm if i try to spin the tire's it wont just sittes there then starts to move i think it's the presher plat but not shure
Old 07-29-2007, 10:06 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: dont know
The more time you put into writing a coherent post, the more time we will give you with responses.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 07-29-2007, 11:14 PM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
Re: dont know
I am not really sure what your problem is...it sounds like you are just having a hard time burning out...which like you said is kind of pointless in the 1.8
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
Old 07-30-2007, 09:32 AM
eclipse98gst's Avatar
eclipse98gst eclipse98gst is offline
Re: dont know
Your clutch is going out, buy a new factory clutch
Speed: a scalar quantity which refers to "how fast an object is moving." A fast-moving object (my DSM) has a high speed while a slow-moving object (your Camaro) has a low speed. An object with no movement at all has a zero speed (most Mustangs).
