Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 07-29-2007, 09:05 PM
johnifanx98 johnifanx98 is offline
overheat when got stuck
The typical scenario is:
I drive 40 miles on highway, and it's OK.
I get off highway, and am stuck due to slow local traffic. Then i see temperature go high.
When I drive faster, the temp turns normal again.
Confused, seems like faster, cooler?
Old 07-29-2007, 09:37 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Re: overheat when got stuck
Yeah, sounds like you might be low on coolant and/or your radiator fan isn't working. Do you ever hear the fan come on?
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 07-29-2007, 10:17 PM
the coolant is OK. But just have no idea how to check the fan... Is it suppose to running all the time when car has been started?
Old 07-30-2007, 09:47 AM
C2Z06 C2Z06 is offline
Send a message via AIM to C2Z06
Double check the coolant.
1)Wait until the engine cools.
2)Take the cap off
3) Restart the car
4) When you car gets warm enough the water pump will kick on and watch the fluid, if it drops then add warm-hot water/antifreeze directly to the radiator
Old 07-30-2007, 10:19 AM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
the waterpump should be flowing at all times as its belt driven... although when cold the thermostat will prevent most of the coolant from circulating. so, with the engine cold, top off your radiator and cap it and start the car. hold your revs to about 2500 RPM and watch your temp gauge, as it reaches normal operating temp you should hear your fan come on, if it doesnt and it starts to overheat, you may have a bad sensor or blown fuse.
Old 09-10-2007, 02:59 PM
diver4ever's Avatar
diver4ever diver4ever is offline
Hi there. I have a friend who has the same problem as the guy above. He has changed everything and has no leaks. The mechanics have checked it and said it could be his head gasket. Does this sound right to you? It doen't to me. He has no knocking, no leaking of oil or water and I checked his spark plugs and no indication that the gasket has broken. His heater works, his air conditioning works, fans go on, changed his thermastat and new radiator. The only thing that hasn't been changed are the hoses. Don't know if this would make a difference because nothing is leaking. What else should I check on his car?
Old 09-10-2007, 05:21 PM
maxassassin's Avatar
maxassassin maxassassin is offline
Send a message via AIM to maxassassin Send a message via MSN to maxassassin
unless your blowing some milky white clouds his head gasket would be fine. typically its as they said low coolant or the fans not coming on. im sure youd see a leak if there was one.
06 cbr 600 f4i
91 civic hatchback.
96 nissan pathfinder
Old 09-10-2007, 06:06 PM
Kind of a Big Deal
is your friends fan coming on?? if not it could be the temp sensor or the fan fuse
Old 09-11-2007, 04:09 PM
wiseguy01's Avatar
wiseguy01 wiseguy01 is offline
to check fan switch go to the thermostat housing find the temp switch\fan switch take the pigtail of and jump it fan should come on if so switch is bad
