Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 07-29-2007, 08:13 PM
sportsman sportsman is offline
2000 grand cherokee cruise control
My jeep air bag light stayed on and the cruise control didn't work.
I changed the clockspring . This solved the problem for the air bag light but my crusie control still don't work. The crusie light will come but will not set the speed. Any suggestions?
Old 07-30-2007, 02:03 AM
Bob D. Bob D. is offline
Re: 2000 grand cherokee cruise control
Does the heater/a/c only blow through the defrost?
If so it has lost the vacuum; the HVAC mode doors and cruse control use the same vacuum source. Look for a cracked or disconnected vacuum hose in the engine compartment.
Old 07-31-2007, 07:46 PM
[quote=Bob D.]Does the heater/a/c only blow through the defrost?
If so it has lost the vacuum; the HVAC mode doors and cruse control use the same vacuum source. Look for a cracked or disconnected vacuum hose in the engine compartment.[/quote
The air vents work like they should.
Old 08-05-2007, 04:49 PM
Carlito1957 Carlito1957 is offline
I have a 98 with exactly the same problem. Did you come up with a fix.
Old 08-11-2007, 08:46 PM
NO, IT STILL DON'T WORK! I CAN'T FIND ANY VACUMN LEAKS.
NOW IT HAS A BAD MISS IN IT AND I CAN'T FIND THE CAUSE .
Old 08-19-2007, 03:28 PM
I have fixed the miss by changing the injector on #4 cylinder. I still can't find
the problem with the cruise control. I checked the switch with the OHM meter & I have no reading on the set side. It may be the switch.
