Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 07-29-2007, 07:44 PM
fordfan4life fordfan4life is offline
2001 JGC Trans & starting issues (probably not CPS)
1. My sister has an 01 GC with 98,000 miles on it. A few months ago, it began having troubles starting when it was cold - she said she would have to crank it about three times (and each crank was longer than usual); the check engine light came on around the same time. After research on the internet and a trip to AutoZone to get the code/s read, I determined the problem to be the CPS (2 codes came back: CPS and misfire on cylinder 1, so I figured that the CPS was causing the misfire).
I spent a Saturday installing the new CPS, but the problems didn't seem to stop (the Check Engine light did go out, though, after I had it reset at AutoZone -- all other symptoms remain). So what I'm wondering is if I could have bought and installed a bad CPS (I REALLY HOPE NOT) or something else I haven't considered yet.
2. More recently, the transmission seems to shift a little harder than it has in the past. She says that it really is noticeable when under heavier load -- when the AC is on, etc.
Any suggestions would be really appreciated!
Old 07-30-2007, 06:21 AM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Re: 2001 JGC Trans & starting issues (probably not CPS)
It is very possible you could have gotten a bad CPS and I don't trust autozones electrical parts to much, and if it was a BORG WARNER brand (I don't think AZ carries BW anyways) thats even worse.
But there are a few other possibilites as well - did you disconnect the battery when you replaced the CPS? Jeeps are very picky about this, if not that could be your problem. I would return the part and get another one (should be under warranty) and remember to disconnect the battery.
R.I.P. - 94 Jeep Grand Cherokee Limited 5.2L V8 Quadra-Trac, 3" Budget Boost, K&N FIPK Gen II (Cold Air Intake), FlowMaster American Thunder (Exhaust).
W.T.T.F. - 1998 Jeep Grand Cherokee 5.9 Limited - Deep Slate Pearl - K&N FIPK GEN II (COLD AIR INTAKE), Altezza Tails and Crystal Clear Front end light with HID Kit and NP242 Swap.
