Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-29-2007, 06:14 PM
itsme71190 itsme71190 is offline
Send a message via AIM to itsme71190
smoking badly
from start up to shut off. my 95 GS smokes bad...
anything u no that can help?
Old 07-29-2007, 06:36 PM
KoDKingVegeta KoDKingVegeta is offline
Re: smoking badly
What kind of smoke is it? Black? Blue, White? When you pick up does it stop smoking or does it get worse?
1989 Honda Civic DX Hatchback
*STOCK
Twisted Motor Sports
The Cell Games
^--Help Revive an old forum, Come Join
-=flash to the future: (three months) "As stock prices continue to climb for superglue... ppl are frantic.... *static* KoDKingVegeta buys the whole market out *Static* fix *static* dashboard from *static* UK... *end of flash to the future*=-
Old 07-29-2007, 09:48 PM
inatalonIXLR8 inatalonIXLR8 is offline
Re: smoking badly
Need more input.......
Hey anyone ever heard of running some kind of powder into an unfiltered intake ? This old man I struck up a conversation with at Canadian tire said he and his "hot rod" buddies used to do that to deglaze the cylinders.
95 Talon Tsi AWD 5spd
2.4L4G64 6bolt JE8.5EagleTorqueplatedFully ballanced-balanceshaftARP Ferrea1mm 1Ghead ported/polished HKS264/272 fidanzagears turbonetics copy polished GT3076R VbandTial38mm cometic prothane mounts SARD850 stage4 Compclutch+flywheel 3"exh Walbro255 rewired Innovate wideband O2 ForgeBOV Autronic standalone innovative wideband[url=http://img494.imageshack.us/my.php?image=talonandhelicopter5as.jpg]
Old 07-31-2007, 01:36 PM
Re: smoking badly
black/gray.
it smokes no matter wat i do. but when i do push it, it does go away a lil. but then again im moving so its hard to c. but as im sittin still it is really bad
Old 07-31-2007, 09:54 PM
Re: smoking badly
Black smoke: Black smoke is a result of an excessively rich mixture of air and fuel entering into the cylinder area. The proportion of fuel is more in the air to fuel ratio. This fuel rich mixture does not burn completely in the combustion chamber and produces black smoke coming out of the tailpipe, thus affecting engine performance and fuel economy. Although rich mixture is necessary for engine start-up, black smoke is indication for a faulty injection system or sensors in the engine computer. Get your car tested for emission and call your mechanic for engine tune-up.
http://www.buzzle.com/articles/troub...-problems.html
*STOCK
The Cell Games
Old 08-01-2007, 04:56 PM
eclipse98gst's Avatar
eclipse98gst eclipse98gst is offline
Re: smoking badly
try changing the o2 sensor and your spark plugs. It sounds like your just not burning up all your fuel.
Speed: a scalar quantity which refers to "how fast an object is moving." A fast-moving object (my DSM) has a high speed while a slow-moving object (your Camaro) has a low speed. An object with no movement at all has a zero speed (most Mustangs).
