Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 07-29-2007, 03:10 PM
niceguypmp3 niceguypmp3 is offline
'98 88 LS trans problem
On my '98 88, when i take off from a stop with moderate or higher throttle, the car shudders really hard until i let off the gas. Also there are times that it shifts really hard. Local dealership said its a common problem with the shift solenoids and valve body sticking, but couldnt guarantee that the parts would fix it. Car has 142k on it now and i've put 45k on it since i bought it and its done it since i got it. i'm afraid the trans might go out anytime. Anyone else had these problems and have a solution to it? any help would be appreciated.
Old 07-29-2007, 06:33 PM
auto trainy auto trainy is offline
Re: '98 88 LS trans problem
The dealer is correct and a good trans shop will be able to do the work a lot cheaper than the dealer,it is in the pressure control solenoid system and its all internal and is common for that and other years,good luck.
Old 07-30-2007, 03:31 PM
maxwedge maxwedge is offline
A990 racer
Welcome to AF, this can also be caused by an engine misfire, the proper diagnosis involves road testing with a trans function scanner to look at slippage errors and tcc slippage a.
