Go Back   Automotive Forums Car Chat > Oldsmobile > Oldsmobile Classics
Old 07-29-2007, 02:55 PM
Pat 68 Pat 68 is offline
68 Cutlass stalling
My 68 Cutlass has a tendency to stall when in drive. I really have to press the gas lightly to get it moving. Flooring it off the line always kills it. In park I can rev it all I want.
350 motor, 2 speed trans.
I have very little mechanical skill, so I am hoping there is an easy fix that I am over looking.
Old 07-29-2007, 03:44 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Re: 68 Cutlass stalling
Welcome to AF! I am Moving this thread to Oldsmobile Classics forum.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 07-30-2007, 03:13 PM
maxwedge maxwedge is offline
A990 racer
Welcome to AF. This can be caused by several things, carb too lean, bad accelerator pump, timing set wrong, these things all must be checked out by someone experienced with this generation vehicle.
Old 08-10-2007, 10:01 PM
blkmonday's Avatar
blkmonday blkmonday is offline
sounds like your timing is off...welcome to the wonderful world of a points ignition. if your going to keep this car i suggest unless you change over to electronic ignition you read the posts on setting points and setting timing. oldsmobiles are famous for the timing to walk around..(i think my 66 425 holds the record for timing jumps)..i suggest "pertronix" electronic conversion kit..very easy install...and no more points. otherwise i siggest a new set of points and a good tachometer/dwell meter and some feeler guages and a good classic olds manual and a timing light.
